Results 1 to 1 of 1
Thread: 2.5L 175 merc
05-10-2021, 02:01 PM #1
2.5L 175 merc
Selling it as a drop-on. New rings, new crank bearings, new head gaskets, new voltage regulators, oil injection deleted, carbs cleaned. Will need a proper break-in for the new rings. Less than 1hr on the rings. Steel reeds, uncut heads...nothin special.
Previous owner said it had low compression in one cylinder. I took his word for it and tore it down without doing a compression check. I expected to find scored walls or a cracked ring or something...I found nothing wrong. That concerned me that I couldn't find anything wrong...but after looking carefully at everything I decided to just put new rings in it and put it all together and see what happens. Once together it had great compression and started right up... I think its 125 +/- 1 psi across all 6.
Last pic is from when I first pulled the heads. It has not been blown up.
$1800
Come pick it up in person or you figure shipping.
I will build a crate if I have to, but prefer local pickup.
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
13ft delta 60 merc looking for 18 pitch stainless chopper prop 13 spline 60hp merc
By boogie in forum Props, Setup, and RiggingReplies: 6Last Post: 07-14-2019, 11:48 AM -
merc water pressure gauge part# to match older merc gauges??
By syclone01 in forum General Boating DiscussionReplies: 3Last Post: 09-09-2016, 10:48 PM -
Lifeline jacket, merc manual, merc lifting ring, LU flush adapter
By John S in forum Misc. Parts and AccessoriesReplies: 5Last Post: 07-13-2016, 02:21 PM -
Mercury Tech: 50hp 4cyl Merc vs. 70hp 3cyl Merc vs. ??? - Weight vs HP - Opinions??
By Steve2ManyBoats in forum Technical DiscussionReplies: 6Last Post: 02-22-2016, 07:25 AM
