Results 1 to 5 of 5
    Dec 2006
    In-line 115 adi merc questions reeds exhaust baffle plate???
    So I grabbed a 115 adi from a freind hadn’t run a in a year or two.
    Mounted it on my hull (you dont really want to know ) cut down the shaft for a 20 inch from a 25 got it fired up and it was hard starting and just didn’t sound right.
    felt like
    it was a reed, pulled a carb , sure enough bad reed so I’m kinda committed at this point
    so Now I gotta learn inlines, always had V6s 2.5s and 3.0s
    so have it down to the bare power head right now about to pull it and split the cases this is not a Speed boat motor.
    two things, I have is that it’s definitely in need of a reed change that’s visually confirmed , and on number 2 piston I was getting small water droplets consistently. No other cyl. Yet bore scope of cyl looks
    Nice and clean. Reversion? Or something more?
    engine is a nice clean freshwater all
    It’s life engine.
    not looking for performance mods just want to make it a good runner .
    main concern is reeds thinking maybe a set of boysen might be good not for performance but in case it ever injests the reeds it maybe won’t wipe out a cylinder.
    and want to know if there’s anything I should do w exhaust plate, read about some issues w those ? Totally new to inlines and my v6s always ran like a top so limited experience working on those as well .
    thanks in advance for any info.
    President :
    CPBA
    Connecticut Performance Boating Association
    Dec 2006
    Read
    the Jeff grigg paper on the exhaust plates anyone have pictures of these plates ?
    also anyone used hylomar M
    on these ?
    or even hylomar red 100
    https://hylomar.com/en/hylotyte-red-100/
    President :
    CPBA
    Jan 2020
    Pinole, Ca
    Exhaust plates meaning the divider plate and the cover plate? I got them laying around in a big pile and maybe some NOS ones. I had a habit of condemning more I-6 than I put back together. They made good money in scrap before the aluminum price took a dump. Never did have a problem with leaking exhaust plates, but I always put the old gasket sealer from merc on the gaskets before I bolted them up.
    Dec 2006
    Was that the mercury epoxy sealant?
    President :
    CPBA
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by ct20sutphen View Post
    Not epoxy. It was non-hardening.
  1. In Line 4 baffle plate difference
    By Tom Smyth in forum Technical Discussion
    Last Post: 12-11-2006, 05:46 PM
  2. Need 2.5 260 or Promax exhaust baffle plate
    By Eagle One in forum General Boating Discussion
    Last Post: 09-10-2003, 03:07 PM
