Results 1 to 11 of 11
    Apr 2018
    Bedford-Texas
    Need Some Input 92 175 HP Mercury Propeller Help
    I have a 1993 Skeeter 200SX with a 1992 175HP Mercury Outboard. Iíve had this boat since 2018 and have been disappointed that for some reason it will only run 50 mph @5500 rpm. Seems to me this boat should be a little faster. The current prop on the engine is a 5 blade ďHigh FiveĒ. Iím not sure of the pitch, as I could not find it etched on any of the blades. Iím wondering if I should purchase a 3 blade turbo prop for it in the hopes a getting a little more speed. Anyone have any ideas that might help would be greatly appreciated.
    Houston, TX
    High 5 props are usually associated with pulling water toys or heavy stuff. Probably jumps up but then goes flat. Yes, you will want a 3 or 4 blade prop. Check out bassboatcentral.com and post this in the Skeeter forum. You'll have your answer tomorrow.
    Apr 2018
    Bedford-Texas
    Thanks !
    Jan 2020
    Pinole, Ca
    Quote Originally Posted by Crappiecrazy View Post
    Thanks !
    Yes, you will see high fives on a lot of heavy bass boats and some similarly shaped ski V hulls. They pop you out of the hole good but are not ideal for max speed.
    I would be looking into a LazerII or similar with some vent holes and pvc plugs so that you can adjust the cavitation to get your ideal holeshot. If you can't find any info on the bass boat forums I would start somewhere around a 21 or 23 pitch.
    Also, do you have your engine on a jack plate, and if so have you messed with the height?
  5. Thanks Crappiecrazy thanked for this post
    Apr 2018
    Bedford-Texas
    thanks for the input
    Apr 2018
    Bedford-Texas
    do not have a jack plate
  8. Likes 25two.stroke liked this post
    Houston, TX
    So if you want any speed out of your rig, you probably have to get your motor up a little. Set the boat level using the trailer tongue and then trim the motor down to neutral position - level cavitation plate. Now measure from the center of the prop shaft to the ground, and from the bottom of the back of the boat to the ground. Subtract one from the other and post it here - that's "prop to pad" height. What mounting holes are the bolts in on your motor? Post a pic?
    I would pass on the Laser II prop for your boat as the blades are not big enough to carry your Skeeter. Probably looking at a Tempest or similar. Check BBC - the boys there can give you a specific setup that will work on day one.
  10. Thanks Crappiecrazy thanked for this post
    Apr 2018
    Bedford-Texas
    Thanks - I will check the height this weekend.
    Sep 2011
    maryland
    Post some pics if possible. But like Rgsauer said. check your running height. It sounds like you are running low in the water.
  13. Thanks Crappiecrazy thanked for this post
    Houston, TX
    Here's a couple of links. Just trying to save you time and $$. One is for Skeeter in particular and the other is for Setups.
    http://www.bbcboards.net/forumdisplay.php?f=49&
    http://www.bbcboards.net/forumdisplay.php?f=117
    Please do post pics of your rig.
  15. Thanks Crappiecrazy thanked for this post
  16. #11
    Apr 2018
    Bedford-Texas
    what do you think about the Tempest Plus Propeller 21p ?
  1. 2001 225 mercury optimax triple purchase input
    By Steelborn in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-13-2015, 11:43 AM
  2. INPUT to Propeller-Year end issue
    By gdfatha in forum Racer's Hangout
    Last Post: 11-15-2004, 10:15 PM
  3. Region 5-input To Propeller
    By gdfatha in forum General Boating Discussion
    Last Post: 11-15-2004, 11:49 AM
