Results 1 to 6 of 6
    Feb 2020
    MinneSnowda
    2.5 175hp big charging system question
    Hey folks. I'm new to the Merc world.
    My 2.5 has 2 rectifiers.
    When I hooked up my tach (grey wire) I had no signal, so switched it to the other rectifier. I now have tach.
    I'm getting 14 volts charging.
    Is this normal or is only one of them working?
    (Motor runs perfect)
    Thanks
    Jun 2014
    United States
    You need to get somebody else’s opinion, but I would think the one that you hooked it to and the tack did not work is bad.
  3. Likes rgsauger, Smalltownbassin liked this post
    Houston, TX
    What year motor?
    Feb 2020
    MinneSnowda
    I believe 1996.
    Aug 2020
    Dickson, Tennessee
    14V is normal but if the tach doesn't work on one regulator, its bad. Better off to change them both out.
  7. Likes DieselDood liked this post
    TX......somewhere?
    cut tha "bullet" connectors off, solder and heat shrink tha connections on 2 new reg/rect's....
  9. Likes Smalltownbassin, DieselDood liked this post
  1. Battery question - 40 amp charging system??
    By skeeterboy in forum Technical Discussion
    Last Post: 05-11-2021, 02:58 PM
  2. Water cooled regulator 2.4 charging system question
    By idvette in forum Technical Discussion
    Last Post: 07-01-2020, 06:38 AM
  3. Mercury Tech: Charging system question
    By hydroguy21 in forum Technical Discussion
    Last Post: 07-29-2011, 08:23 PM
  4. bridgeport EFI charging system question
    By Banana Boat in forum Technical Discussion
    Last Post: 11-11-2002, 12:42 AM
