Results 1 to 4 of 4
Thread: First time timing a outboard
05-07-2021, 11:04 PM #1Junior Member
- May 2020
- FL
- 10
I just finished the rebuild. This is my ser. # OT147230
Attachment 486625
I have all spark plugs out, throttle cable removed. Throttle arm against idle stop and should be set to 0* - 9* ATDC so that can be anywhere between 0* and 9* ATDC right? and at full throttle stop should be at 26* BTDC and not 20* BTDC, because 26 is at cranking speed and not full rpms correct?
I just want to make sure on the timing numbers in the the manual. This is the manual.
And also on the trigger plug has bare wires. Can I cut the wires back and repair the wires some how or do I need to buy a new trigger?
Thanks in advance and for all for the help thus far super forum thanks all.Last edited by Ron357; 05-07-2021 at 11:11 PM.
05-10-2021, 12:05 AM #2
Jay Smith racing sells a dial indicator for establishing top dead center, setting your pointer, and dialing in your marks. Best $75 I ever spent.
23 degrees is safe. 25 is Max for general running. Better have good fresh fuel for 25. Break it in at 23 degrees max.1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
XstreamVking liked this post
05-12-2021, 04:22 AM #3Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
The right way to repair that is to buy new pins for that connector and cut those wires back to good insulation and recrimp new ends and insert them in to the connector. But I dunno if you have enough slack in the wire. That looks like a weatherpack connector to me. But, I am not a merc guy to say 100%. It may be something else. But a weatherpack can be re-done. But those wires definitely need to be repaired.
05-12-2021, 08:32 AM #4Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
If the wires look like that, I would not trust the trigger. Water has a way of "wicking " up into open wires. And of course into the trigger too.
Mercury Tech: Carb 2.0L 150 idle setting by timing or blade position? (one more time)
By pcrussell50 in forum Technical DiscussionReplies: 4Last Post: 06-22-2019, 04:27 AM -
price on timing a outboard
By rideordie in forum Technical DiscussionReplies: 5Last Post: 07-06-2011, 04:31 PM -
outboard paint/head gaskets/timing
By Archie in forum Technical DiscussionReplies: 2Last Post: 12-17-2007, 01:17 AM -
First Time Outboard Owner
By Sutphen20 in forum Technical DiscussionReplies: 0Last Post: 05-31-2005, 07:09 PM
