Results 1 to 3 of 3
    Aug 2014
    Houston
    1996 Johnson 225 Lower unit compatibility?
    I am trying to figure out if I can put a lower unit from a 2005 Evinrude 225 DFI (E225fhlsob) on to a 1996 Johnson 225 venom (j225stlede). I figured someone on here knows.
    Also when i put a dial indicator on the shaft there is about .003" of movement when turning the shaft. how much movement is acceptable?
    Thanks
    May 2001
    Hickory NC
    Yes it will fit. The 05 unit is a bit larger and a very small ratio change. .003 is ok
    Aug 2014
    Houston
    Thanks
  1. lower unit compatibility
    By tautog_33 in forum Technical Discussion
    Last Post: 05-15-2012, 09:07 PM
  2. OMC Tech: Lower Unit Compatibility
    By LSaupe in forum Technical Discussion
    Last Post: 09-22-2009, 06:48 AM
  3. OMC Lower Unit Compatibility
    By twister123 in forum Technical Discussion
    Last Post: 09-21-2005, 11:05 AM
  4. Ocean Pro lower unit compatibility, help!
    By Doug Gifford in forum Technical Discussion
    Last Post: 08-14-2004, 04:11 PM
