Results 1 to 13 of 13
    Mar 2002
    Pensacola, Fl.
    280 Dying when getting on plane?
    Went out last weekend with my 280 for the first time, the motor ran great for the first hour!
    Stopped and floated for fifteen minutes or so, cranked it up a couple times to idle out closer to the bank.
    When we left the motor cranked up and got on plane , ran for about a mile at 5000k and it died like someone turned the key off.
    I was able to restart but when trying to get on plane it died again immediately as if the key was shut off.
    Before hitting the water in preporation for the season I put a new Bosch fuel pump on, new fuel line and new pre and post pump filters.
    I got a tow in, I looked for anything loose and fuel leaks but all looked good.
    Anyone have any idea of what to look for on a 280?
    Thanks Stoney
    Jan 2020
    Pinole, Ca
    TPS or ECU
    Put a volt meter or DDT on the motor and watch the throttle position and see if it is dropping off or doing funny fluctuations. I've seen them trip out at certain rpms.
    Worst case the ECU is corrupting.
    Were you watching your fuel pressure? Any way that pump could've been cutting out? I know they are loud, but at 80 mph you can't hear them in every boat. Sounds like your fuel pump cut off or that tps is failing.
    Mar 2002
    Pensacola, Fl.
    I don't have a fuel pressure guage, I did barrow one and look at the pressure when on the hose. It was holding 39 psi I have good wiring and good voltage to the pump but anything is possible when running.
    I will look at the the TPS with my DVM.
    Thank's Stoney!
    Ft. Lauderdale, Fl
    Check the water/fuel separator for water. Just to be sure.....
  5. Likes 25two.stroke, luv2gofast liked this post
    Nov 2003
    Simi Valley, SoCal
    Need to figure out whether to look left or right...fuel or electrical. I have a long test wire that I use to find those kind of problems It has 3 LED's on one end and bare wires on the other. I connect it to an injector, a coil and the fuel pump. Go for a drive and see which one stops lighting up. I've never used it in my boat but tracked down lots of car problems with it. You could do the same thing with a 12v test light but one at a time. That's how I used to do it but decided it would be much faster to check 3 things at once. Of course that doesn't cover a fuel flow issue but at lease you can find out if the pump is running.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
  7. Likes powerabout liked this post
    Sep 2017
    ontario
    Cover off all basics as usual , electrical - connections and coils . Fuel and plugs . A DDT would help greatly .
  9. Likes stoneman liked this post
    Nov 2003
    E.Texas
    was chasing same issue, cleaned and spread cannon plug connections.
  11. Likes stoneman liked this post
  12. #8
    north carolina
    Start simple. Sounds like a fouled plug
  13. #9
    Oct 2015
    ont canada
    Do a compression test
    Ft. Lauderdale, Fl
    Quote Originally Posted by tomoad View Post
    All 6 plugs would have to be very fouled to make it shut off.....................
    north carolina
    Quote Originally Posted by flabum1017 View Post
    Possibly. But that why I said start simple. Mine wouldn’t even crank. After running bout 4 miles. Stop for bout 1hr then wouldn’t crank. Changed plugs 2yr ago & still running. These sob’s do some crazy stuff sometimes
  16. #12
    umatilla,FL
    check your battery grounds and check the motor main harness connection for corrosion
    Sep 2017
    ontario
    Stone did you make any basic checks on this yet . Trying to assist as I'm trying to Kick -Political section -
    if everyone gets assisting with a tech thread - I enjoy that more sooo any headway , I own one - 280 and I find this site great - if others will take the time.
    DDT helps
  1. Mercury Tech: 280 keeps dying!
    By crimeinc2 in forum Technical Discussion
    Last Post: 09-22-2012, 07:38 AM
  2. Johnson 225 dying
    By DSMITTY in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 06-21-2012, 09:46 PM
  3. New Crossflow Dying at WOT
    By SpeedDemon in forum Technical Discussion
    Last Post: 10-11-2002, 09:38 PM
