Results 1 to 2 of 2
Thread: reed screws
05-06-2021, 09:21 PM #1
reed screws
my reed screws didnt have lock washers when i disassembled, installed CCM reeds and the screws intrude into the inside of the cage close to an 1/8".should i use lock washers to bring the screws out of the airflow or use locktight and not be concerned with it?
05-07-2021, 05:03 AM #2
They don't come from the factory with lock washers. You can order screws that are 1/8" shorter or like Ive done in the past Carefully grind 1/8" off them and reinstall with blue Loctite
25two.stroke liked this post
Looper reed screws
By Captain75 in forum Technical DiscussionReplies: 0Last Post: 02-26-2013, 05:56 AM -
Screws in Reed cages
By Mudwrench in forum Technical DiscussionReplies: 11Last Post: 08-28-2009, 12:00 AM -
OMC reed cage screws
By gearhead in forum Technical DiscussionReplies: 6Last Post: 07-12-2008, 07:51 PM -
Reed Attaching Screws
By 4Speed in forum Technical DiscussionReplies: 5Last Post: 06-01-2003, 09:46 PM -
What is the torque spec on the reed screws again ????????
By Balzy in forum Technical DiscussionReplies: 5Last Post: 03-25-2003, 10:19 AM
