Results 1 to 7 of 7
    Mar 2009
    San Antonio, Texas
    Need power head help
    Got my power head rebuilt. 1998 mercury 200 EFI. Dropped it back on and I cannot get the shifter to work. Will not go into neutral. Took the linkage off and neutral seems to be forward and in gear clicks one back and will not switch. Any help would be greatly appreciated.
    thanks
    never pulled the lower unit since pulling the powerhead
    Jan 2020
    Pinole, Ca
    Sounds to me like the gearcase was in reverse when you pulled the powerhead and somehow the shift rod got picked up and re-oriented to the fwd gear position. So the gearcase is in reverse and the top is in forward. If this (or the opposite) happens then it wont move at all.
    Drop the lower, put it in neutral, hook the shifting up in the powerhead with it in neutral, and put them back together.
  3. Likes David - WI liked this post
    Mar 2009
    San Antonio, Texas
    I was thinking that might be the case. Kids! Thanks for the help. I just wanted to hear it from someone else before I dropped the lower unit.
  5. Likes 25two.stroke liked this post
    Jan 2020
    Pinole, Ca
    Its only after puttin 25 powerheads on that you hit the hole with the first try...and then even after that they might not go on right every time. We all forget stuff now and again.
    Its worse when you build a gearcase and you put it all together and it shifts backwards...thats the worst feeling ever...you know you gotta take it ALL apart. Thankfully dropping the gearcase only takes 7 nuts/bolts.
  7. Likes David - WI liked this post
    I don't know what's wrong with you two... nobody has ever caught me doing that.
  9. Likes 25two.stroke, sonicss33 liked this post
  10. #6
    Jan 2020
    Pinole, Ca
    Oh shoot, did I say I made a mistake?
    I never done that in my life.
    Ya, disregard what I said. We all perfect around here, just like mother merc
  11. Likes David - WI liked this post
  12. #7
    Mar 2009
    San Antonio, Texas
    yeah I bet that is a real bummer!
  1. New 280 R.O.S power head.
    By vanfossen in forum Outboard Engines
    Last Post: 01-13-2015, 01:32 PM
  2. Replies: 9
    Last Post: 08-05-2013, 03:20 PM
  3. Replies: 23
    Last Post: 01-18-2012, 10:13 PM
  4. power head swap for more power
    By wrangler7883 in forum Technical Discussion
    Last Post: 07-20-2007, 10:02 AM
