Results 1 to 13 of 13
Thread: Tilt Trim gauge
05-06-2021, 04:15 PM #15000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 100
- 28
Tilt Trim gauge
Hey folks
I just installed a Merc 2.5 on my Champion 184. I installed new Faria Gauges. I got everything hooked up and the Tilt Trim gauge goes the opposite of what the T/T is doing. If it's all the way down, it shows that it's up. If it's all the way up, it shows down. I took the sensor off, rotated the paddle 180 and reinstalled it. It worked as intended till I shut the key off, then it went back to being the opposite.
Any suggestions?
05-06-2021, 04:27 PM #25000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 100
- 28
Lol!
It's pretty hard to mess up. One wire to sensor... key power, ground and illumination.
If I could flip it I would! Lol
05-06-2021, 04:29 PM #3
Sounds like the ground wire and the sender wire got switched in the wiring harness somewhere....
05-06-2021, 04:36 PM #45000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 100
- 28
I'll double check, but the gauges were all wired when the dash was out, and the illumination circuit works.
The sensor on the motor just has a ground wire that is grounded at the sensor and the actual sensor wire that goes to the gauge. Which is a new wire that I ran.
05-06-2021, 04:37 PM #5
05-06-2021, 04:40 PM #65000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 100
- 28
Yup?
Yup its right or yup to check or...
05-06-2021, 06:23 PM #7
Did you get the right gauge? Some engines have senders that go from 33 - 230 OHMS, and others that go from 230-33 OHMS.........
25two.stroke liked this post
05-06-2021, 08:09 PM #85000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 100
- 28
I bought the one for Merc.
I just crawled under the dash. All is right.
I must have gotten the wrong one.
Crap.
Thanks
05-06-2021, 09:11 PM #9The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
...what bum said. gauge salespeople don't have a clue what they are selling...
05-07-2021, 08:16 AM #105000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 100
- 28
05-09-2021, 03:18 PM #11
Part numbers:
https://fariabeede.com/2-pages/prod_...edGauge=2_trim"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
05-09-2021, 03:20 PM #125000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 100
- 28
Interesting! I went with the 13016, looks like I needed 13017.
05-09-2021, 03:26 PM #13The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
Tilt N Trim won't Tilt N Trim on 2006 Tohatsu MD 50 B
By ZO6 in forum Technical DiscussionReplies: 12Last Post: 12-31-2018, 09:29 PM -
Mercury Tech: Add Tilt/Trim Gauge to Mercury XR4/Magnum II Outboard
By sameri in forum Technical DiscussionReplies: 9Last Post: 04-05-2018, 07:46 PM -
Aftermarket trim: Panther power trim and tilt bracket opinions?
By mxz in forum General Boating DiscussionReplies: 4Last Post: 10-28-2016, 06:05 AM -
Mercury Tech: Temperature Gauge and Trim Gauge
By mbrien in forum Technical DiscussionReplies: 0Last Post: 03-10-2010, 09:35 AM
