Results 1 to 15 of 16
Thread: Tygon
    Jun 2020
    Tygon
    Ok, what is the part number for the good, Jay Smith endorsed, Tygon tubing. I see so many part numbers, then Jay put a part number up then a few posts later said it was the wrong one but it will work?
    Please tell me the McMaster part number for yellow Tygon that will resist fuel.
    Jan 2020
    Pinole, Ca
    Jay Smith:
    I’ve used tygon tubing ( fuel and lubricant grade ) I buy from McMaster Carr for 25 years never had any issues with any instillation anywhere on any Mercury V-6 , maybe the product your using has to thin a wall thickness OR it’s not rated for fuel lubrication application ?? I also secure it to every barb with ty straps ...I use at least 1 50’ spool a month
    Part # 5552k23 from McMaster - Carr ......404 346 7000 Atlanta , Ga.
    BTW Every 2.5 V-6 High Performance Motor ever made that came from racing division came stock with the same yellow tygon I use daily ??
    MY BAD I put wrong McMaster part number up the number listed is correct !!!That former number was the bigger tygon I use for water line from poppet to top of block , steel sleeved motors!!!
    Jay
    Jan 2020
    Pinole, Ca
    It all gets hard after a while, no matter what you use. The black fiber reinforced stuff used on factory carb motors lasts longer but its not as pretty...
    I choose pretty/service regularly rather than ugly/lasts forever
  4. Likes Forkin' Crazy, Capt.Insane-o liked this post
    Jun 2020
    So even when he says, "my bad I put the wrong Mcmaster up" was he speaking of the phone number?
    So, 5552k23 is correct? ok
    Jan 2020
    Pinole, Ca
    Yeah what you see there is correct. The number he posted before he edited it was the 1/4 or 3/8 line used for water I think.
    Jun 2020
    I just ordered 25ft. Thanks brother
  8. Likes 25two.stroke liked this post
    charlotte,nc
  10. Likes Charli, HStream1 liked this post
    Mar 2002
    Pensacola, Fl.
    What about TY wraps made for fuel line or tubing? The specialized one that have the rounded head that seal better?
    Anybody have a line on them?
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by stoneman View Post
    just google hose zip ties and you will see plenty!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jan 2020
    Pinole, Ca
    None of them look adequate for 1/4" o.d. lines. I typically use regular mini zip ties; they work if they are not too tight.
  14. #11
    Jun 2020
    The ones you get from Mercury? Or am I thinking about the fuel injector tie wraps?
    Jan 2020
    Pinole, Ca
    They are one and the same. Zip ties with ears so they dont deform the hose when you tighten them down. I have never seen mini ones though. Only ever seen small spring clamps.
Name:	sip ties ofnAne.JPG
  16. #13
    Mar 2004
    Brooklyn Park, MN
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  17. Thanks 25two.stroke thanked for this post
  18. #14
    Mar 2002
    Pensacola, Fl.
    Thanks!!
  19. #15
    Jan 2020
    Pinole, Ca
    There we go! I couldn't find it, but thats what you need!
  1. Tygon!
    By Merc 2.5 in forum Technical Discussion
    Last Post: 04-17-2021, 10:07 PM
  2. Tygon Oil Lines
    By bouyhead in forum General Boating Discussion
    Last Post: 04-10-2018, 11:21 AM
  3. Tygon Tubing
    By laglass69 in forum Technical Discussion
    Last Post: 01-27-2011, 12:01 PM
  4. Tygon Tubing FYI
    By Ranger976 in forum Technical Discussion
    Last Post: 05-09-2008, 03:27 PM
