Results 1 to 3 of 3
    Feb 2021
    Canada
    Quicksilver Paralift jackplate torque
    I've just finished rebuilding a Quicksilver Paralift jackplate (12" setback, 500lbs) which I got used, paint job was in rough shape so I took it all apart and sandblasted, repainted, then took trim/tilt motor/ram apart to rebuild it as well. Works great now, looks great too.
    My question however is does anybody know the torque specs for the 4 bolts on each corner (that slides into the bushings)? I can't find documentation on this anywhere, did a search here also. I did use an electric torque adapter to determine the breakaway torque when removing the nuts, highest value I got was 32 on one of the corners, all other 3 were lower or didn't even register on the adapter. Since they were all different, I'm not even sure if 32 was the right number to look at either.
    I know breakaway torque is always lower than tightening torque, which apparently can range between 5-15%, so I added 10% to the 32 for a value of 35 ft lbs, and I torqued all 4 to that value. This slightly clamped the aluminum onto the edges of the bushings, which looks fine and it all does still work (jackplate goes up/down without issue, albeit slightly slower than when it wasn't torqued at all).
    Thanks in advance for any info anyone can shed on this!
    Jul 2004
    Connecticut
    On those units I switch to Grade 8 bolts and torque to 32lbs. Nice units although a bit heavy.
  3. Likes XstreamVking liked this post
    Feb 2021
    Canada
    Thanks for this info. This has worked well for me so far and it is holding well!
  1. Quicksilver paralift problem
    By Bunger in forum Technical Discussion
    Last Post: 08-27-2019, 07:13 PM
  2. Quicksilver Paralift jack plate
    By charvelplayer in forum Bass Boats and Sport Fishing Rigs
    Last Post: 08-19-2019, 09:22 AM
  3. WTB Quicksilver paralift jackplate, 500 lb. capacity.
    By roger s in forum Misc. Parts and Accessories
    Last Post: 09-17-2017, 10:32 PM
  4. Quicksilver Paralift Hydraulic Jackplate
    By smiley88 in forum Misc. Parts and Accessories
    Last Post: 08-04-2016, 02:51 PM
  5. Quicksilver paralift 12 inch
    By Z71_SS in forum General Boating Discussion
    Last Post: 05-10-2007, 02:40 PM
