Results 1 to 2 of 2
    Jan 2005
    Winnipeg
    HP difference between a 1978 115 T.O.P and a 1986 115?
    Seems like this is the year of motors for me. In addition to a 3.0L offshore 250 I picked up a 1986 Merc inline (grey stripes) motor. Serial sais its a 1986. I currently have a 1978 inline 6 on my 16' Baja. I bought it as the price was good and it has the integrated power trim as the 78 has the external pump and side cylinders. This should clean the back of the boat up a bit.
    I have read through a few good threads on here and understand that the "later years" had some improvements done and that they are really close in build to the earlier model 1500's? I have read different info that said it occurred after 1976, 1980, and 1985. Is there any difference in my 78 and 86 motors from a HP perspective? they are bot ADI so i thought other then trim they were the same? Paid $625 for the 86 115. compression is good, power trim works, looks in great shape....no spark. Ill get it on a stand and I am sure ill figure the spark issue out.
    79 Baja 16SS w/ 79 115 Merc
    1977 Whaler Montauk w/ 80 Yamaha
    1992 Mastercraft Barefoot 200
    Jan 2005
    Winnipeg
    Awesome. OK That's what I was hoping. So if this 86 is running like it should, I should see a small bump in power. Excellent. I think I heard that when the V6 150 came out they rebadged the 1500 to the 140, the 140 became the 115, and the 115 became the 90. Then when the standard rating came in around 84/85 the 140 got rebadged to the 115, etc and the shuffle happened again. So an 86+ is close in power to the old 1500... Not sure if that's really true though.
    Thanks!
  1. 1978 Mercury 850 XS
    By Mtnbike1 in forum Outboard Engines
    Last Post: 05-11-2017, 08:30 AM
  2. 1978 What?
    By Gary_C in forum General Boating Discussion
    Last Post: 09-09-2014, 10:39 AM
  3. HELP, 1978 175 johnson
    By deadend in forum Technical Discussion
    Last Post: 04-06-2011, 08:04 AM
  4. 1978 Inline 6 Mercury Prop fit a 1986 Mercury 2.4 175?
    By WSJR1 in forum Technical Discussion
    Last Post: 07-31-2010, 03:51 PM
  5. 1978 27' Cobra
    By Mastercraft241 in forum General Boating Discussion
    Last Post: 11-01-2007, 12:16 PM
