Results 1 to 9 of 9
    Nov 2018
    LaPlace, Louisiana
    Bosch Fuel Pump for 280
    Looking to see if anyone can help me out, looking to buy a Bosch Fuel Pump for my consumer 280 and was looking for a part number so I can order one
    Thanks
    Quote Originally Posted by Killah View Post
    Thanks
    Summit Racing
    Bosch Automotive 61944 - Bosch Electric Fuel Pumps
    Fuel Pump, Bosch 044, Electric, 200 lph, External, Inline, Gasoline, Universal, Each
    Part Number: BCH-61944
    ( 18 )
    In Stock (more than 10 available)
    Estimated Ship Date: Today
    • Free Shipping
    $175.99
    Add To Cart
    • Compare
    • Wish List
    Loudon Tn
    Just for your info. You don't need to run expensive Bosh. Any pump with correct mph will work. I run 280 with no limiter and an inexpensive fuel pump keep up with rpms fine. My two cents
    Jun 2014
    United States
    I’d get a Deatschwerks 250 lph pump. I’ve used them for five years with no failure.
    Sep 2008
    louisville
    Here’s what I use .
    Attached Thumbnails Attached Thumbnails 22245F0B-CBF6-4B4C-8FAF-1864957BC6D6.png
    Sep 2017
    ontario
    What are the specs - from Mercury - for the 280
    You can find videos that show you the difference between real Bosch 044's and the fagizzies.
    The Summit ones are real .. Flee bay .. not so much .
    Plainville, CT
    Just have an XR4, but just started running a Carter. The Bosch looks a lot smaller. You need a regulator with that?
    A Carter 4600HP deadheads @ 6 - 7 PSI . No reg needed.
    A Carter 4601 deadheads @ 10 - 14 PSI . Yes reg required.
    Bosch 044 deadheads around 125+ PSI .
    You can run them on carbureted to EFI motors , but you will need a return type reg to get them to stabilize at any pressure . 4 to 90 PSI , it will feed them all.
    My tanks feed from the top , so I use a (no restrictive squeeze ball for me) 4600 to feed a remote (swirl pot) tank that feeds a 044 .
    When the Carter's are running , the Bosch "thinks" it's submerged .
    Even this up and then straight down deal needs to be re-primed if it sits too long between uses ... or you want to change the filter. Thats what the -4 (blue cap) on the filter housing is for. Bosch instruction manual says ... never run them dry.
  10. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  1. HELP! new 280 and Bosch fuel pump, pump dosen't want to go????
    By blkmtrfan in forum Technical Discussion
    Last Post: 05-20-2003, 07:26 PM
  2. Bosch Fuel Pump...
    By JohnR225 in forum Technical Discussion
    Last Post: 04-27-2003, 01:13 PM
