Results 1 to 12 of 12
    Oct 2006
    Emory TX
    Operation Vector commencing
ID:	486376thinking of using this for core with no plywood
    https://www.boatbuildercentral.com/p...oneycomb-core/
    1986 Tahiti Warrior rude 4.0 v8
    1976 Skeeter Odyssey rude 235 sold
    92 18' Mirage Jaguar xr4 sold
    HydroStream Vector 200 efi
    Jun 2018
    Floating around
    When researching my materials I found a couple threads about that product being not suitable for hull coring. It’s for decking only iirc
    Oct 2006
    Emory TX
    Hmmm thanks, I've seen some debate on best material, haven't made up my mind yet. Probably go back balsa.
    Just don't want to ever do this again
    Any recommendations would be awesome
    Jun 2018
    Floating around
    Biggest struggle I had in materials was choosing the core. I was so focused on a wood free ( rot free ) build I was going to use diviny cel but in the end I too, went with balsa. For two reasons; 1. I bought the hull stripped and the core came with it 2. It’s the strongest
    Plus I figure I take good care of my things and I’m resin infusing it as well as gel coating the inside so it should last a while. If water gets into the core whether it’s foam or balsa the hull needs repairs anyways so it’s not as if foam core cures all troubles.
    Oct 2006
    Emory TX
ID:	486396Click image for larger version.
ID:	486397Click image for larger version.
  6. Likes tnelsmn liked this post
    Oct 2006
    Emory TX
    What did you go with for stringers?
    Oct 2006
    Emory TX
    Stringers directly to hull or on top of balsa core? looks like originally straight to hull but I've seen some builds on top of core?
  9. #8
    Stingers on core that's glassed over will spread the load better than directly on the glass bottom. But, either way will work.
  10. Thanks hydroViper235 thanked for this post
    Calgary, Alberta
    Quote Originally Posted by hydroViper235 View Post
    I suggest you do more research on that core’s performance in slamming loads before using it in a bottom. Floor however is a good bet.
    Matt
    Oct 2006
    Emory TX
    Going with end grain balsa
  13. Likes tnelsmn, LakeFever, MattGreen liked this post
  14. #11
    Oct 2006
    Emory TX
    Good news on side note, got a title and reg. on the hull. I bought the hull in AR and they dont have titles, so I was nervous being here in TX. Filled out 100 forms and I got a TX title
  15. Likes XstreamVking liked this post
  16. #12
    Minneapolis MN
  1. Faulty tach operation
    By HighOctane in forum Technical Discussion
    Last Post: 10-16-2014, 08:22 PM
  2. 'splain this theory of operation
    By Capt.Insane-o in forum General Boating Discussion
    Last Post: 01-02-2010, 10:25 AM
  3. operation repo
    By scc82 in forum General Boating Discussion
    Last Post: 08-08-2009, 07:00 PM
  4. ~Hi-Performance Boat Operation~
    By thaw ripper in forum General Boating Discussion
    Last Post: 01-23-2004, 06:25 AM
  5. Jackplate operation
    By Ac in forum General Boating Discussion
    Last Post: 05-14-2001, 12:19 PM
