Results 1 to 13 of 13
Thread: Head bolt torque sequence
04-29-2021, 05:11 AM #1Junior Member
- Apr 2021
- Michigan
- 18
I finally got my gaskets was wondering if someone could post the torque sequence and ft lbs? 1987 175 blackmax
Tx mike
04-29-2021, 06:47 AM #2
Start in the middle and work your way around. I torque to 35 lbs. On used bolts do NOT +90*.
RockTeam Junk
"Aquahaulinass" thanked for this post
04-29-2021, 11:15 PM #3
And do them to 15, then 25, then 35 lbs. Three torquings. And oil your bolt threads with two stroke oil.
04-30-2021, 02:46 PM #4
04-30-2021, 04:02 PM #5
Thats how I learned , in to out.
Then I started hangin out in the Top/Fuel pits and saw all of them torqueing out to in. Finally axed a crew guy , he said : The gasket is already tryin to get out .. grab it , best ya can ta make it stay .. Ahh OK ..
rgsauger liked this post
04-30-2021, 05:28 PM #6
Have you found that works? In to out is a standard for damn near everything by all mfrs. Block halves, exhaust coers, intake manifolds, cars planes, wood siding... everything in to out.
But it don't really matter how anyone else does it or how the industry does it if a different way works ....
05-03-2021, 04:04 PM #7
05-03-2021, 05:23 PM #8
The reason for not doing the +90 is for accuracy, not because the bolts snap. 30 ft-lbs, 40 ft-lbs...whatever you tighten it is FAR LESS than the tensile strength of those bolts. They can hold up to way more than that. The threads in the block strip before the bolts.
If you sheared a head bolt torquing it down to 30 or 35 then I would replace ALL the head bolts because they are compromised (either corroded, were over torqued in the past, or were some poor quality Chinese steel like they use to build our presently failing bridges and skyscrapers).
The 35 ft-lbs comes from an approximation of the 30ft-lbs + 90. Thats what the magic motor builders on here have figured out.
05-03-2021, 06:18 PM #9
New bolts are TTY hence the +90. Once the bolt has stretched the plus 90 will only strip threads in the block.
RockTeam Junk
05-03-2021, 07:41 PM #10
Manual says +90 for the connection rod screws too, what damage could be done if using used bolts and turning it +90?
I actually couldn't turn my head bolts the full 90, I felt something was gonna strip, maybe I got another 45
05-03-2021, 07:55 PM #11
Not seeing that on the connection rod bolts in my 2.4 book. Maybe they said that in later books. Theres two things that will fail: the threads or the bolt. Connecting rod bolt failure can be catastrophic...bolt overtorqued, stretched, compromised...holds on at idle and revs freely...spin it up to WOT or jump a wake and when you come back down the extra stress pops the heads off the bolts...no fun.
05-03-2021, 08:09 PM #12
Hmmm yea well see what happens, thought I followed the manual, and who knows my torque wrench could be off, thought I tightened the bolts tight with some consciousness around stripping
05-04-2021, 07:33 AM #13
Just tighten them all to 15, then 25, then 35 lbs and call it good. Head gaskets are cheap if it spits one
2.4 head torque specs and sequence
By Nielmcque in forum Technical DiscussionReplies: 2Last Post: 07-19-2018, 08:14 AM -
Mercury Tech: 3.0 Head Bolt torque?
By RedonYellowKillaFellow in forum Technical DiscussionReplies: 2Last Post: 10-26-2013, 09:50 PM -
Mercury Tech: Head bolt torque
By FAST-J in forum Technical DiscussionReplies: 2Last Post: 09-06-2012, 01:58 PM -
Torque Sequence For 2.4 merc head?
By evenpar in forum Technical DiscussionReplies: 1Last Post: 10-05-2010, 07:36 AM -
Mercury Tech: Head Bolt Torque ?
By Dart'nFart'n in forum Technical DiscussionReplies: 2Last Post: 05-25-2009, 08:53 AM
