Results 1 to 15 of 28
Thread: 115HP Crossflow info needed .
04-27-2021, 08:05 PM #1Junior Member
- Apr 2021
- Connecticut
- 19
Hello , I have been reading tech info and advice here for a few years but now I have a few questions.
I picked up a 115 powerhead that may be replacing my 1993 90HP VJ90TLETS .
The 115 powerhead is from a 94 turbojet and needs a rebuild . I do see some things on this engine that I don’t see on my 90HP .
#1 is the small hoses going from the intake manifold to the bypass covers and one to the crank case , I think this is a fuel bleed/recovery system so my questions are As follows.
What’s the purpose?
Do all 115 engines have them ?
What years was this system used? ( I’m wondering if this is even a 94 powerhead)
What are the pros and cons ?
Is this system needed ?
The fuel pump pulse line also comes from a bypass cover , can I use the manifold and bypass covers from the 90HP and omit this from the 115 ?
All input would be appreciated.
Thanks
04-27-2021, 10:26 PM #2Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Does it still have the VRO?
Later engines had changes to the re circulation system, (all HP models changed in the same year) so they did idle lots betterLast edited by powerabout; 04-27-2021 at 10:30 PM.
04-28-2021, 06:54 AM #3Junior Member
- Apr 2021
- Connecticut
- 19
Thank you . Yes the Turbojet had the VRO mounted in a canister off the engine with a fuel spill recovery hose that went to the stbd. side intake manifold . This fitting can be easily plugged. I will not be using the VRO fuel pump , it failed on my 90HP . I do believe the non VRO fuel pump I used on my 90HP still used the pulse hose and fitting.
04-28-2021, 05:03 PM #4Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
It most likely is a 94. The recirc lines are on all of my 90's bubblebacks. Its NOT necessary. But it removes excess oil from the reed cage area running slow. The older motors dont have it. Well, my 1978 140 didnt have it. And I cant remember if my dad's 84 115 had them. It helps with idling from what I understand. My 112spl uses the manifold for the pulse fitting for the fuel pump.......directly behind the pump. The vro 115 uses a check valve lower on the manifold and plugs the fuel pump pulse fitting with a screw.
04-28-2021, 07:58 PM #5Junior Member
- Apr 2021
- Connecticut
- 19
Thank you , My initial thoughts where to can the heads , manifold and bypass covers with the fittings , check valves and hoses from this 115 and use the ones from the 90HP.
I don’t spend too much time at idle . Maybe a few minutes at the dock to let it warm up.
I am still in tear down stage with the 115 , I just separated the case and found what looks like scoring from the crankshaft counter weights on the inside of the case. , pistons will be out soon .
04-28-2021, 08:10 PM #6Junior Member
- Apr 2021
- Connecticut
- 19
So another question I have since I have some scoring going on in the crank case cover , I’m sure from shot crank bearings , Are the crank case covers interchangeable between the 90 & 115 ?
04-30-2021, 08:13 AM #7
powerabout liked this post
04-30-2021, 09:20 AM #8Junior Member
- Apr 2021
- Connecticut
- 19
Thank you . I am sure I will have more questions , I am more comfortable with small block Fords.
04-30-2021, 02:48 PM #9Junior Member
- Apr 2021
- Connecticut
- 19
The pistons are out , stbd. side pistons & cylinders scored , 1 piston looks like it was bottoming out and hitting the case at the bottom of the cylinder , port side pistons and cylinders clean but the rod bearing retainers scored the bearing race on the rods. Time to find a machine shop !
05-01-2021, 09:30 AM #10Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
No bearing race on the rods. If rods are scored they need to be replaced.
keefallan liked this post
05-01-2021, 11:50 AM #11Junior Member
- Apr 2021
- Connecticut
- 19
Well there was a race but the bearings where so worn they scored the rods . The parts from my 90HP will be going into this 115 crank case as long as they are good . My 90 was rebuilt at one point it’s bored .030 ,
05-02-2021, 04:33 PM #12Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Show some pics of the carnage Kevin........it sounds for some interesting pictures.
05-03-2021, 02:34 PM #13Junior Member
- Apr 2021
- Connecticut
- 19
05-03-2021, 02:44 PM #14Junior Member
- Apr 2021
- Connecticut
- 19
The above photos show where the crankshaft counter weights marked up the case .
05-03-2021, 02:47 PM #15Junior Member
- Apr 2021
- Connecticut
- 19
OMC Tech: 1992 115hp Crossflow questions, RPM, heads
By RoyE in forum Technical DiscussionReplies: 12Last Post: 07-04-2013, 12:04 AM -
1994 115HP Johnson Crossflow help
By omcforever in forum Technical DiscussionReplies: 8Last Post: 06-15-2012, 03:28 PM -
OMC Tech: is '93 115hp a desireable v4 crossflow
By pcrussell50 in forum Technical DiscussionReplies: 18Last Post: 05-11-2010, 04:41 PM -
Idling Problems OMC v4 115hp crossflow
By MIKE OSBORNE in forum Technical DiscussionReplies: 2Last Post: 05-19-2005, 03:25 AM -
235 crossflow info needed
By fyremanbil in forum Technical DiscussionReplies: 16Last Post: 05-29-2004, 05:19 PM
