Results 1 to 1 of 1
04-25-2021, 03:03 PM #15000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Phantom 25 1985 - 450R - Max5 props 15 vs 15,25 dia
HI!
I have made an order for a 450R for my Phantom 25 V bottom. Its a 1985 model UK offshore race design. No steps - ol style runner.
At this moment I have a 400R on it. Best speed is 89 mph with a Max5 25 prop at 7,060 rms. 1:1,75 gear ratio. Most of the times we end up at 88 mph at 7,040 rpms, which translates to 7% slip. Which is good for a classic V hull design. I run the propshaft 2 inches above the bottom. The trim is fairly neutral and boat runs high and flat.
With the 450R I estimate a top speed with a Max5 27 to approx 95 mph. Mercury offers Max5 with 15,25 inch diameter and 15 inch diameter. Merc advertise 15,25 to have less slip. The question is if the 15,25 will be faster than the proven 15 inch diameter, since its most likely will give more transom lift ...
What do you think?
Cheeers, Toffen
Phantom 25 1985 - Merc 450R
By Toffen in forum General Boating DiscussionReplies: 64Last Post: 08-10-2021, 02:44 PM -
By Toffen in forum Props, Setup, and RiggingReplies: 5Last Post: 11-18-2020, 02:31 PM -
Looking for props to run on my Phantom 18
By Christopher Bates in forum Propellers WantedReplies: 0Last Post: 11-25-2018, 10:02 AM -
Props for a Phantom 25 w/PM 300 SVS
By Toffen in forum Props, Setup, and RiggingReplies: 1Last Post: 01-25-2004, 05:21 PM
