Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
  1. #31
    Maine
    You're leaking from that top metal fitting. you can see oil in the threads, on both sides of the fitting. There is your leak, its not the plastic plugs.
    J
    Quote Originally Posted by RedBusDriver View Post
    Im not 100% but I think it may be one of the fittings or it could be the end of the hose.
    After work today I will go down there again and clean it and try to find the leak, I think I have the right orings at home.
    If I remember correctly the Quicksilver/Merc system uses ORFS fittings. (oring face seals)
    This is one of those situations where even if its right my brain still wont accept it.
    Attachment 486255Attachment 486256Attachment 486257
  2. #32
    Apr 2011
    WI
    Quote Originally Posted by SkywayGT View Post
    J
    I appreciate the input. I cleaned all oil then physically layed underneath the helm and watched the leak. The pic is 90 degrees off. with the angle of the helm fluid was leaking from yellow plug and tracking down the back of helm pump then out onto the 90 degree hose fittings.
    I will update when new pump is in
    2019 Crestliner 240 Rally DX CWDH Tritoon Merc 200 DTS
    2014 Checkmate 2000 Pulsare BRX Merc 250 Pro XS
    Powerquest 290 Enticer FX Twin 454 Sold
    Hand Built 10ft Aluminum Jet Boat 1500cc Kawi 4stroke Sold
    Playcraft 24ft Tritoon conversion with 235 GT Johnson Sold
  3. #33
    Apr 2011
    WI
    So I pulled helm and resealed everything. Those yellow plastic plugs still have a drip.
    With the plug out I can see what I assume is some sort of a bypass or check valve maybe for a dual station/helm setup.
    When turning the wheel normally with the plug out no fluid is seen but as soon as I hit the extent of the steering and give a bit more turn pressure it will spit fluid out.
    Obviously turning the wheel with the boat on the lift is minimal pressure but at speed and turning im sure there is much more pressure on this valve and that is causing it to leak.
    I dont think going from a plastic to a metal plug is the correct solution, I think whatever that valve is has failed.
    Can anyone confirm what those 2 ports are with the plugs.
  4. #34
    I know it's not what you have, but on the Hynautic helms there is a third "bypass" hose that goes back to the hydraulic reservoir... if you turn past the range of the cylinder the excess pressure "blows off" and the fluid goes back to the reservoir.
    I don't know how many different "SeaStar/Hynautic" helms are set up to be used on the Hynautic-style system though.
  5. #35
    Apr 2011
    WI
    This system appears to be a teleflex with quicksilver tags on it.
    Whats weird is its a 3 bolt flange instead of the common 4.
    Im heading back to the dealer today and discuss this, hoping to talk to a tech.
  6. Likes David - WI liked this post
  7. #36
    Plastics can have a very small crack that's not visible under normal inspection. If it's leaking after being sealed it must be cracked.
    Apr 2011
    WI
    agreed, but under full load turning id bet there is 500 to 750 psi at the helm/lines, no way plastic would hold that back.
    I think Im just going to ask them to split a sea star pro system with me.
  9. #38
ID:	486571Click image for larger version.
    Just random internet photos, but I haven't seen any with plastic plugs.
  10. #39
    Apr 2011
    WI
    Just for the hell of it, Ill pull that yellow plug and go get a few brass ones if I can find one to match.
    These yellow plugs have an o ring at the base of the head, I dont think they were NPT but im hoping.
    Ill throw 2 brass ones in there and see what happens.
  11. #40
    May 2016
    keys
    I've only ever seen those plugs used as shipping plugs, to be replaced with metal or corresponding hose upon install.
    If there is a machined boss under the lip of the plug to accept the o ring then there most likely straight thread pipe, ORB, o ring boss. which would be strange to have when the others are clearly tapered pipe. I wouldn't expect both types on the same helm.
    If no boss then standard pipe plugs will work. They may even work in the straight thread better than the plastic, but won't be 100% correct.
    ANTI40​It's just an idea.
  12. #41
    Apr 2011
    WI
    Quote Originally Posted by Whaaaaat View Post
    They were 1/4" pipe thread. Got them in but it's gusty cold and choppy out there. I'll run it this weekend
  13. #42
    Jan 2019
    Ontario, Canada
    No more leaks?
  14. #43
    Apr 2011
    WI
    Still has a few drips,
    Im waiting for the dealer to dig into the parts for SilverSteer 2.0 system.
    I think thats the route we are going.
  15. #44
    Apr 2011
    WI
    Dealer offered to buy the boat back so I walked away.
  16. Likes tnelsmn liked this post
  1. Hydro steering...how much slop should it have?
    By rgsauger in forum Technical Discussion
    Last Post: 06-23-2020, 03:58 PM
  2. steering slop
    By David in forum Technical Discussion
    Last Post: 07-17-2012, 07:08 PM
  3. Slop in hydraulic steering?? Litle help please
    By bill mason in forum Technical Discussion
    Last Post: 07-22-2009, 08:08 AM
  4. how to tighten slop in lower end of steering arm?
    By silverbullet02 in forum Technical Discussion
    Last Post: 02-08-2008, 08:49 PM
  5. Steering slop
    By 83PREDICTOR in forum Props, Setup, and Rigging
    Last Post: 01-13-2008, 07:05 PM
