Results 1 to 15 of 44
Thread: Hyd steering slop
04-25-2021, 01:48 PM #1Member
- Apr 2011
- WI
- 42
Hyd steering slop
Trying to tighten up the steering on my checkmate.
It has factory installed hyd steering,
Quicksilver helm pump cant read the PN
Merc Steering cylinder 8M0050097
The helm was low on fluid when I got the boat this spring, had about an inch of travel on steering cylinder when moving the motor by hand.
I picked up the bleed kit and ran a quart through it with no bubbles at the end, this drastically improved the steering but its still not right.
Over 30 mph feels like I have to spin the wheel at least 180 to get a response.
When on the lift I can turn the wheel all the way to lock and still turn the wheel with some effort.
I had a few drops on the floor under helm pump but degreased it and ran for 30 min today with no signs of leak.
If this wasn't a quick boat I wouldn't care, but I'm just not comfortable at WOT with some trim.
Compared to my pontoon with power hyd steering that wheel has the slightest amount of wiggle and is tight no slop at the motor.
Im leaning towards an issue in the helm pump.
What do you think?
Boat is a 2014 so maybe its time to just replace everything? What's the consensus on pump displacement?
ThanksLast edited by RedBusDriver; 04-25-2021 at 01:52 PM.
2019 Crestliner 240 Rally DX CWDH Tritoon Merc 200 DTS
2014 Checkmate 2000 Pulsare BRX Merc 250 Pro XS
Powerquest 290 Enticer FX Twin 454 Sold
Hand Built 10ft Aluminum Jet Boat 1500cc Kawi 4stroke Sold
Playcraft 24ft Tritoon conversion with 235 GT Johnson Sold
04-25-2021, 02:36 PM #2
Has air trapped in a line somewhere, would be my guess. Might have to tilt the trailer or even back down a boat ramp or ditch and bleed again? Some of them are a bitch depending on how they routed the lines.
04-25-2021, 02:38 PM #3Member
- Apr 2011
- WI
- 42
I bought the bleeding kit that loops the bleed fittings at the cylinder. then you just spin the wheel and it circulates letting air out at the helm. I will bleed it again this week. It might be just me too. this is my first quick outboard, way different that my 290 PQ
04-25-2021, 03:51 PM #4
I would look at how your lines are run, if there's a "high spot" it will trap air... I think you would really have to spin the wheel pretty fast to get the air to go "downhill" any distance. I know it doesn't seem like it would be that bad... but I had a hard time getting the air out of mine.
04-25-2021, 03:53 PM #5Member
- Apr 2011
- WI
- 42
David - WI liked this post
04-25-2021, 05:52 PM #65000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
I purchased the kit from Outboard Specialty Tools as I had a leaking end seal on my Euro hydraulic steering ram. I changed the seal and did the feed & Bleed and everything was fine... < than 1/4 inch travel. After a few passes it felt a little sloppy. I did the feed & bleed again and it took about another 1/3 - 1/2 cup of fluid. I always put a mark on the bottle so I can see how much I added. You have to turn the helm FAST 20-30 times in each direction (my hoses are about 18') and occasionally squeeze the bottle.
04-25-2021, 05:54 PM #7Member
- Apr 2011
- WI
- 42
04-25-2021, 08:10 PM #85000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Bleed kit sounds like a good concept, if air can't get in thru the loosened bleed ports around the threads. If that insert a issue, I think it could be, couldn't the steering wheel be removed then hook a drill up to the shaft and really give it a spin?
Maybe another person at the back moving the motor back and forth while your spinning the wheel. There's plenty of places inside that cylinder for tiny bubbles to get trapped.Last edited by Whaaaaat; 04-25-2021 at 08:16 PM.
ANTI40It's just an idea.
04-26-2021, 07:25 PM #95000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
Forgot to mention that I did move my motor left to right - port to starboard with the bleed ports open during the purge process.
04-28-2021, 10:19 AM #10Member
- Apr 2011
- WI
- 42
I went down to the lake yesterday to bleed the system again. Didn't notice any improvement, but I did find that there is a leak at the helm pump.
I never noticed it before because it would drip on my pants, it was warm enough yesterday that i was in shorts and felt the drops.
Seems to leak under heavy load, 50mph and turning.
Waiting to hear back from my dealer to see what they want to do about it.2019 Crestliner 240 Rally DX CWDH Tritoon Merc 200 DTS
04-28-2021, 11:47 AM #11
I’d try some Lucas Transfix in there. It doesn’t take much maybe an ounce or two. Then bleed it like this
https://m.youtube.com/watch?v=pix1t7ROQ6UHydrostream dreamin
04-29-2021, 07:35 AM #12Member
- Apr 2011
- WI
- 42
04-29-2021, 12:23 PM #13
All hydraulics are pistons and rubber seals. All Lucas does is soften up the rubber to help the seals do their job at a price of slightly thicker viscosity which I seriously doubt would cause any issues in the minor amounts I suggested. That said if funds are there new is always better
04-29-2021, 01:14 PM #14Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Where's it leaking from? A fitting under the dash, or from the helm shaft seal?
04-29-2021, 02:37 PM #15Junior Member
- Feb 2020
- Finland Kotka
- 9
For installation I used Loctite 542 pipe glue no leaks
Hydro steering...how much slop should it have?
By rgsauger in forum Technical DiscussionReplies: 8Last Post: 06-23-2020, 03:58 PM -
steering slop
By David in forum Technical DiscussionReplies: 10Last Post: 07-17-2012, 07:08 PM -
Slop in hydraulic steering?? Litle help please
By bill mason in forum Technical DiscussionReplies: 14Last Post: 07-22-2009, 08:08 AM -
how to tighten slop in lower end of steering arm?
By silverbullet02 in forum Technical DiscussionReplies: 4Last Post: 02-08-2008, 08:49 PM -
Steering slop
By 83PREDICTOR in forum Props, Setup, and RiggingReplies: 2Last Post: 01-13-2008, 07:05 PM
