Results 1 to 2 of 2
Thread: wh(18) carb jet question
04-22-2021, 08:02 AM #15000 RPM
- Sep 2006
- 456
- 160
- 9
- 43
- 49
From reading I gather the idle jet controls fuel flow through the whole rpm range.
If the idle jet was increased(to lean idle) would this cause the whole system to lean?
ei: would a 52 idle jet and a 72 main be leaner set up then a 46 ij and 72 mj?
If that is the case would leaning out the idle mean I would want to richen the mains?
ei If I went from 46 idle to a 52 would I want to go from a 72 main to 78 for about the same total amount of fuel?Last edited by coffeeguy; 04-22-2021 at 08:03 AM. Reason: spelling
04-23-2021, 09:15 AM #2
WH series carbs idle jets control "ONLY" idle circuit.. as soon as you you go off idle they no longer mater.............
coffeeguy thanked for this post
Carb question
By ivlakeman in forum Technical DiscussionReplies: 12Last Post: 01-12-2021, 09:46 PM -
carb question
By gambling209 in forum Technical DiscussionReplies: 0Last Post: 09-13-2010, 08:50 AM -
Mercury Tech: Carb question
By rdkvector in forum Technical DiscussionReplies: 3Last Post: 09-13-2010, 12:25 AM -
carb. question
By Deacon in forum Technical DiscussionReplies: 3Last Post: 12-31-2008, 08:25 PM -
carb question
By skintback in forum Technical DiscussionReplies: 1Last Post: 08-19-2002, 07:17 AM
