Results 1 to 10 of 10
Thread: Ram steering
    Aug 2020
    Ram steering
ID:	485890So I recently changed my steering to side mountClick image for larger version.
ID:	485891 but I can’t get my turning even like the piston isn’t long enough or something is there any attachments I can put on the arm to get a couple more inches out of it like a coupling or something
    Jan 2020
    Pinole, Ca
    Pictures? What manufacturer of ram/ plate?
    Aug 2020
    Hyanutic I can’t figure out how to put up pictures
    Jan 2020
    Pinole, Ca
    Oh I was about to buy one of those. I haven't messed with one yet, so if anyone is familiar with the hynautic side ram steering then can you please chime in? Tony and I would both appreciate it.
    The only hynautic rams I have messed with are the front mount k6, which is in my opinion the best front mount cylinder ever made.
    I have/had one on my HST... still on the 2.4L mid in the shed. It must be installed wrong... obviously with the motor pointing straight ahead the ram has to be in the middle of its travel.
    Either mounted to the wrong hole in the wingplate or the wrong ram? Hard to guess without photos?
    Jan 2020
    Pinole, Ca
    Is it possible for you to post a pic of your mid setup? I'm about to put one on a 2.4 when I get it...Thank you for your time and response!
    Nothing fancy.
    Attached Thumbnails Attached Thumbnails 20210420_170300.jpg   20210420_170315.jpg   20210420_170330.jpg
    Jan 2020
    Pinole, Ca
    Nothing fancy.
    Cool, thank you very much!
  9. Likes David - WI liked this post
  10. #9
    Ft. Lauderdale, Fl
    Are you talking about the Hynautic one that screws into the tilt tube? If so, which link arm are you using? one from a K-10 won't work, you need a standard one like what comes with the engine...... similar to this:
  11. #10
    One thing... not sure it's cause & effect but I noticed my driveshaft is twisted in the splines and because the wing plate is sandwiched between the mid & the exhaust plate; the driveshaft doesn't engage all the way into the crankshaft?
    Just an FYI... not even sure the wing plate caused it; I bought it this way.
  1. Wire with pulley cable steering vs Hydraulic steering on race boats
    By 27Fountain in forum General Boating Discussion
    Last Post: 05-12-2019, 07:32 PM
  2. Alternative steering helm to Mercury Verado power assisted steering
    By Toffen in forum General Boating Discussion
    Last Post: 12-12-2015, 04:15 PM
  3. Replies: 3
    Last Post: 08-02-2015, 11:38 AM
