Results 1 to 14 of 14
Thread: It broke
04-19-2021, 06:45 PM #1Junior Member
- Apr 2021
- Michigan
- 18
It broke
Not too bad plenty of room to weld a nut on. I'll have it out in the next day or two didn't find any sand just 1 small piece of gravel lots of work to not find any blockage guess it's a piece of mind knowing nuttin in there well see what's under the power head soon
David - WI liked this post
04-19-2021, 07:06 PM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
If you liked fighting the head bolts, wait until you take on the powerhead bolts.
04-19-2021, 09:17 PM #3
Ew..that's a skanky one. lol
TEXAS20225 liked this post
04-19-2021, 09:27 PM #4The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
04-20-2021, 06:45 AM #5
Make sure you cover the cyl hole/s up very well before welding on that stud. Spatter will stick to your cyl walls and wreck em
04-20-2021, 08:05 AM #6
There's enough there to grab with a Vice Grip. Heat it up with an oxy/acetylene torch and clamp on and turn it right out.
I've always TIGed the nuts on to avoid any spatter issues.'78 Hydrostream Viking/'98 225 ProMax
04-20-2021, 12:14 PM #7
tnelsmn, XstreamVking liked this post
04-21-2021, 05:29 PM #8Junior Member
- Apr 2021
- Michigan
- 18
It's out and I saved the threads only took me about 4 hours. Ran a tap down all the head bolt holes all's good there next step is to pull the power head and dig all the gravel out of the adapter plate
04-21-2021, 07:39 PM #9
Nice work! I would suggest a set of thread chasers for future use. Running a tap in existing threads could potentially cut material and weaken them. Thread chases don't cut near as much as a tap will. This shouldn't cause concern in your current situation, just a suggestion for the future. Sets can be found cheap on Amazon.
04-22-2021, 03:58 AM #10
Ive done plenty of these in cast iron heads and some in Ali.
If they are broken below the surface the stud can be built up with a tig by dropping blobs of weld onto the top of the stud .
Then when the blobs reach the top of the hole a washer is placed over the hole and the pile of blobs are welded to the washer.
Then the nut is welded to the washer.
The washer system would work on that stud.
04-22-2021, 05:40 PM #11
When you go to re-assemble everything, we usually use Mercury Perfect Seal on the bolts and studs. They stopped making the Perfect seal and now give us Permatex Aviation Sealant which I hate. BRP still makes the Gasket Sealing Compound which is the same as the old Perfect Seal (Unless BRP changed over to the Aviation sealer too.....)
"Aquahaulinass" thanked for this post
04-22-2021, 05:50 PM #12
04-22-2021, 06:17 PM #13Junior Member
- Apr 2021
- Michigan
- 18
Thanks I was wondering about some kind of anti seize for reasonable this fall we are moving back to Florida and I plan to mostly run in the intercoastal water way I can't tell you how much I miss the salt water no matter how bad it is for the motor
04-22-2021, 06:49 PM #14
TefGel is pretty darn good but very expensive. There is an automotive equivalent to the old perfect Seal..... not sure of the brand and name...........
Broke 130++mph
By skydog in forum General Boating DiscussionReplies: 25Last Post: 10-19-2011, 04:54 PM -
need help going broke
By goch in forum Technical DiscussionReplies: 7Last Post: 08-18-2009, 10:28 PM -
She broke 80...
By OntarioStreamin in forum General Boating DiscussionReplies: 27Last Post: 08-11-2005, 08:30 AM -
Broke??
By mike andreola in forum General Boating DiscussionReplies: 1Last Post: 08-27-2002, 07:25 PM
