Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 15 of 125
    Apr 2010
    Indian Lake Ohio
    Mercury Racing’s New V-6 four-stroke outboard engine the 200 APX
    Jun 2020
    Babylon, NY
    Good. Now put a 15" mid and bolt up a sportmaster case and we got ourselves a 200+ HP light enough motor for us smaller single outboard fast boat guys. Come on Mercury its so easy!! Bring us a V-6 200R or 225R thats under 450lbs
  3. Likes Capt.Insane-o, LakeFever, Greg G liked this post
    Apr 2010
    Indian Lake Ohio
    Quote Originally Posted by OceanMarine View Post
    My thoughts exactly, the fact they increased compression and are turning them 6800 rpm is a great thing.
  5. Likes Capt.Insane-o liked this post
    Still can't buy one.
    Jun 2020
    Babylon, NY
    You can build one yourself. Essentially you can take a V-6 225 and the 250R/300R solid mounts bolt right on and throw a sportmaster case right on supposedly. Wouldn't be very cheap but essentially you can make one. So why cant mercury just put those parts together and do it already? Seems so easy to do you almost have to think that they will maybe just a matter of time. Now with this motor they released it seems even easier to make the consumer 15" sportmaster version and be done. But then again you never know maybe it will never happen.
    Jun 2018
    Floating around
    I’m thinking a small better engine with boost. 300hp in the 250-300lb range sounds good
    May 2016
    keys
    No mention of what it weighs. All that money they'll be saving on gas, props, maintenance. Will go to building new hulls to float that pig.
    50% less emissions that an opti? I don't believe that for a second.
    ANTI40​It's just an idea.
  10. Likes David - WI, FMP liked this post
    St. Amant, LA
    At least right direction for repower on smaller older boats.
    22R
  12. Likes JBS liked this post
  13. #9
    Feb 2010
    wisconsin
    25 lbs more than a 200xs...
  14. Likes Capt.Insane-o liked this post
  15. #10
    Problem is, they seem to keep the hi-po stuff out of the consumers hands. Not the mercury of old that sold us the 280 OS and the 300 X thru a dealer.
  16. Likes David - WI liked this post
  17. #11
    Apr 2010
    Indian Lake Ohio
    Hopefully the approach with the 360 and now 200 APX motors is to give something to the racing guys and allow them to work some of the bugs out then in another year we see the 225R V6 and 350R V8
  18. #12
    Quote Originally Posted by wicheckmate View Post
    I can get my boat to deal with that.
  19. #13
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    Check out the sound clip just a bit down the page...
    https://www.mercuryracing.com/engine...n/200-APX.html
    A problem is only a problem when viewed as a problem...
  20. Likes LakeFever, Capt.Insane-o liked this post
  21. #14
    Jun 2018
    Floating around
    That sounds and looks good. Merc what the heck in heck are you guys doing? Release the hounds!!!!
  22. Likes Lake X Kid liked this post
  23. #15
    sounds good on the limiter.
  1. 250 Pro XS 2020 New Mercury engine four stroke
    By Speed & Custom Marine in forum Outboard Engines
    Last Post: 12-23-2019, 11:30 AM
  2. Yamaha 50HP 4-Stroke Used Outboard Boat Motor Engine 20″ Shaft
    By marine planets in forum Outboard Engines
    Last Post: 09-23-2017, 10:40 AM
  3. Replies: 0
    Last Post: 04-14-2017, 05:57 AM
