Results 1 to 3 of 3
Thread: 175 efi reed upgrade
04-18-2021, 03:19 PM #1New Member
- May 2016
- The sticks
I'm considering installing CCMS reeds and stuffers in my 2000 Merc 175 EFI. The engine is bone stock right now. It's on a heavy bass boat. High end power isn't a big concern but I'd love to get a little better planing power with the prop I have. Would I notice any improvement?
04-18-2021, 03:27 PM #2
Slight. Cutting the heads to make 145psi or a light flywheel or all three would be safe things to do that are likely to yield better holeshot. Reeds alone will give you gains but it may be hard to notice.
04-19-2021, 01:54 AM #3
think 2000 is gonna be o-ring head, 'lectronic motor.. not much ya can do with it as is.......... work with props and set up.
bullet123 liked this post
Mercury 7 peddle reed plate, 1" spacer and reed blocks
By tgreen in forum Misc. Parts and AccessoriesReplies: 1Last Post: 02-01-2016, 07:27 PM -
5 pedal reed plate carb and EFI different size reed openings???
By kyleweeky in forum Technical DiscussionReplies: 1Last Post: 01-30-2015, 01:46 AM -
Reed Upgrade Carbed Cross-Flow, worth it?
By LSaupe in forum Technical DiscussionReplies: 1Last Post: 01-11-2008, 04:39 PM
