Results 1 to 2 of 2
Thread: Yamaha 2.6 jetting
04-18-2021, 02:45 PM #1New Member
- Sep 2020
- Norway
Yamaha 2.6 jetting
Just rebuild a 2006 carb 150 Vmax (V150TLR)
New bores, pistons , cut heads 0.04", ccms reeds, 6g500 exhaust divider ,6g5 tuner. Did some light porting and lifted exhaust port height to 1.62". Just started breaking in...feels really strong and sound great, not had it above 4000rpm yet. Set timing at 24 degrees. Using the 32mm Nikki cabs....started with jets from 165 to 170(bottom)Are this jets ok for a start at this setup? Will read plugs as soon as break-in is done.
Am I on the right track here with timing and jets ?
What HP will this setup give?
04-25-2021, 05:59 AM #2New Member
- Sep 2020
- Norway
anyone with similar setup who is willing to comment?
Yamaha Vmax 200ish plugs/jetting
By aaronmt73 in forum Technical DiscussionReplies: 2Last Post: 09-03-2007, 02:25 PM -
Jetting
By yanny_haulinbass in forum Technical DiscussionReplies: 6Last Post: 10-12-2005, 09:45 AM -
WH-15 Jetting
By FishnFast in forum Technical DiscussionReplies: 1Last Post: 09-13-2004, 11:12 PM -
Jetting Yamaha 36 mm carbs
By Markus in forum Technical DiscussionReplies: 19Last Post: 05-07-2004, 06:08 PM -
WH-22 Jetting??
By DUCKY in forum Technical DiscussionReplies: 23Last Post: 01-06-2002, 12:38 AM
