Results 1 to 4 of 4
    Jun 2020
    How to make my 30" 3 liter sound more like this (video) or a Pro-XB
    How can I make my 250 EFI Offshore with 30" shaft sound like a Pro-XB, or like the motor in this video?
    https://www.youtube.com/watch?v=xJzXMAeG87E
    How on Earth are they getting those two different frequencies that are offset from each other in that video, making it sound like twins?
    I should mention, my particular motor has exhaust tube 8263841, in the first picture. Interestingly, later years of the 30" Offshore motor used 833116A7, which is the SAME exact part number for the Pro-XB exhaust tube (second picture). How can this be when one's 30" and the other 20"? And how does this affect the sound?
Name:	Screen Shot 2021-04-15 at 1.14.15 PM.png
ID:	485699Click image for larger version.
Name:	Screen Shot 2021-04-15 at 1.15.26 PM.png
    Also, will switching my ignition and fuel computers with those from a Pro-XB affect the sound? And how would it affect performance?
    Jun 2020
    Surely someone must have some sort of idea?
    Jan 2020
    Pinole, Ca
    So I can answer the question about how a 20" tuner can be the same as the 30" tuner. This is the case because there is a shelf in the can that that gasket and the tuner/liner sit on. In the 20" XB can this sits almost at the bottom of the midsection, and in the 30" mid the shelf will be like 10" up from the bottom of the mid. Even the early tuners were all the same between the 20/25/30 inch motors. In general thats how mercury did it. 25 hp motors, 2.0/2.4/2.5, 3.0 ... they most all have a set size tuner regardless of driveshaft housing length.
    I've seen some 30" mids that have exhaust reliefs about 20" down from the top, and others that direct the exhaust all the way down to the cavitation plate 30" down. If your mid has the reliefs 20" down then the sound would be drastically different than a full length exhaust one. Maybe post pics of your mid from the ground looking up?
    Jun 2020
    25two.stroke, thanks a bunch, very interesting info! In about a week I should be able to pull the LU and get some pics.
    In the meantime, anyone know the answer to the ECM question?
  1. 1986 Mercury Inline Six 90HP Ticking Sound - Video
    By Confuishus in forum Technical Discussion
    Last Post: 05-26-2020, 10:21 PM
  2. 3 liter exhaust sound
    By Ajskennels in forum Technical Discussion
    Last Post: 04-20-2018, 07:49 AM
  3. Mercury Tech: Is this how a mercury 225 should sound? video
    By ultrafinder in forum Technical Discussion
    Last Post: 08-14-2015, 07:15 PM
  4. Replies: 2
    Last Post: 07-29-2010, 02:10 AM
  5. What Kind Of Sound Does A Pig Make????
    By mirage243 in forum The Scream And Fly Lounge
    Last Post: 01-19-2010, 10:04 AM
