Results 1 to 15 of 17
    Nov 2020
    New Zealand
    Bracket serial number different than Block number
    Hi all
    Is it usual for a Pro max to have a different number on the block than on the Bracket?Click image for larger version.
Name:	block serial number.jpg
ID:	485694Click image for larger version.
Name:	bracket serial plate.jpg
    TX......somewhere?
    not unusual for motors that old.. but numbers do match when it leaves merc.. (normally, but it is merc high performance we talkin' about)
    either clamp, down housing etc has been changed and/or powerhead has been changed.. tha powerhead (2000 year) left merc as a complete 15" PM and tha clamp and such left merc as a complete 20" (1999 year)..
  3. Thanks NZ Sidewinder thanked for this post
    Likes 25two.stroke liked this post
    Nov 2020
    New Zealand
    How about this lower unit?Click image for larger version.
    Im not sure it belongs under a Pro Max?
    TX......somewhere?
    best i remember they came with either torque or sport master.. although tha very first PM coulda had a cle (pre sporty)... that looks ta be plain 'ole semi coned "fat block" (no low water pick up) case.. one of tha first ta have tha anodes instead of exhaust slots... so no.
    Nov 2020
    New Zealand
    yes im sitting in my office scraping out the carrier nut thread and now realize its bee coned and the water holes have been bogged up.
    TX......somewhere?
    if possible ($$$) i wouldn't waste time with it.. would try ta source a sporty, coned TM or good late model 200 coned case for it..... jmo.
    TX......somewhere?
    what kinda boat ya got it on?.. if its not at least a mid eighties (mph) boat a coned, lwp may not benefit ya at all...
  9. #8
    Nov 2020
    New Zealand
    If I tell, you probably wont answer my next question.
    But what the hell.
    Modified, padded Sidewinder.
    Those good cases arnt easy to get here in NZ.
    Its got 30 mm prop shaft journals.
    That doesnt seem very American to me?
  10. #9
    TX......somewhere?
    not very familiar with that boat at all.. whats it capable of speed wise with well set up PM?
  11. #10
    Nov 2020
    New Zealand
    Dont know yet
    Its over on the restoration and build up thread but with the pad and the step, low center of gravity 80mph for starters.
  12. #11
    TX......somewhere?
    guess ya on ya on with this one from me anyway.. ya doin' any pictures of tha resto?.. thread?
  13. #12
    TX......somewhere?
    found it....
  14. #13
    TX......somewhere?
    do you not have tha gear case thats on tha motor in tha motor on pallet picture?
  15. #14
    Nov 2020
    New Zealand
    No, it came with the one in the this thread.
  16. #15
    TX......somewhere?
    gottcha.. tha seller kept tha one in tha pallet picture?
  1. Help identify Merc block by serial number
    By FlatSleek in forum Technical Discussion
    Last Post: 07-14-2016, 06:29 AM
  2. Block Serial number
    By dpenny03 in forum General Boating Discussion
    Last Post: 06-21-2013, 08:19 AM
  3. Serial number on block, 2,5EFi.
    By Hydro-T20 in forum Technical Discussion
    Last Post: 06-29-2006, 08:29 AM
  4. Serial Number off of Block?
    By GHOST in forum Technical Discussion
    Last Post: 07-26-2004, 04:26 PM
  5. Where is the serial number on a MERC 2.5 BLOCK?
    By BLUElixir in forum General Boating Discussion
    Last Post: 10-10-2002, 07:33 AM
