Results 1 to 3 of 3
04-17-2021, 05:26 PM #1Junior Member
- May 2020
- FL
- 10
Mercury 150 XR6 head o rings question
The o rings have a flat side not sure if the flat side goes to the block or to the head side. the manual doesn't say.
Also is there any gasket sealer go on the heads at all?Last edited by Ron357; 04-17-2021 at 05:42 PM.
04-17-2021, 05:59 PM #2
I've never had a oring motor to work on but have tore few apart , and seems that flat side goes to block and round side in the head , don't know bout sealant, if orings, etc new should go on dry on clean surface.
Mite could use tad bit grease ( I mean tad bit) to hold orings n place
04-19-2021, 04:09 PM #3New Member
- May 2016
- The sticks
I just installed some a couple weeks ago and didn't know either. I put the flat side facing the block. The compression, leakdown and the "don't pee yourself I'm gonna send it" tests on the water all have been good.
Mercury Tech: Mercury 2000 xr6 head bolts question
By Ron357 in forum Technical DiscussionReplies: 3Last Post: 04-12-2021, 09:04 PM -
Mercury Tech: mercury 2.4 2.5 head question
By glastornjet73 in forum Technical DiscussionReplies: 2Last Post: 04-25-2010, 06:23 PM -
Mercury Head CC question
By wrechin2 in forum Technical DiscussionReplies: 2Last Post: 07-18-2007, 12:59 PM -
Mercury prop and head gasket question?
By Air Dog in forum General Boating DiscussionReplies: 1Last Post: 03-28-2006, 07:47 AM -
3.0L head o-rings
By tide88 in forum Technical DiscussionReplies: 2Last Post: 02-04-2006, 05:10 PM
