Results 1 to 1 of 1
Thread: 2008 250 ho etec 3.4 0 hours
04-15-2021, 06:14 PM #1Registered User
- Aug 2009
- Somewhere
- 58
- 64
- 7
2008 250 3.4 l ho etec
O hours on fresh rebuild
Polished crank
New pistons and wrist pins (wiseco)
Bored 10+ over (couple thousandths clearance added for piston/ring expansion)
New seals , rings , gaskets and bearings ( top main , bottom main, and rod)
New Chris Carson reeds
Injectors cleaned
New poppit valve
New thermostats
New stator
New plugs
20" motor clean clamp and trim pump and cowl
Can be purchased with new SEI lower comes with warranty or no lower
Makes 275-280 hp factory 6,200 rpm
(Can have the heads tighten at additional cost to up HP a lil maybe extra 5-8hp but then requires 93 octane fuel )
Engine was built by one of the most respected OMC/Evinrude shops in FL
Premier Boat repair
Motor is located in Tarpon Springs FL
12k no lower obo
13,500 obo New SEI lower with warrantyLast edited by g-guap; 04-15-2021 at 06:21 PM.
Difference between 2008 etec 200ho & 2011 etec 200ho??
By coojac in forum Racer's HangoutReplies: 2Last Post: 09-02-2013, 05:43 PM -
Etec Hours??
By ROLF in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 7Last Post: 05-15-2011, 09:28 PM -
2008 vs 2009 etec
By budltc in forum General Boating DiscussionReplies: 13Last Post: 10-06-2008, 07:12 AM -
89 v4 140 v.s. 2008 115 etec? help!!!!!!!
By camaroguy67 in forum Technical DiscussionReplies: 15Last Post: 07-19-2008, 10:33 AM
