Results 1 to 7 of 7
04-15-2021, 12:55 PM #1Junior Member
- Apr 2021
- Michigan
- 18
87 black max adapter plate gaskets
I'm going to pull the power head and adapter plate to clean the sand and gravel out that my back flush couldn't get out and I'd like to have the gaskets before I start. I was told it's a 87 175 that has been turned into a 225. It looks to me it had a 1 piece adapter plate. I also think there may have been exhaust work done on it. It's way louder than the bass boats on the lake and has a growl to it. Even the neighbors have come over to tell me how loud it is. If so could it take a special gasket? Could the head gaskets be special size with the 175 to 225 conversion? Ive included pic of all angles of the motor.
Thanks fo the help mike
04-15-2021, 01:00 PM #2
The 1 piece plates all use the same gasket. You can get it or take a 2 pc plate gasket and trim it to match. 2 pc plate gasket original to that motor is thin and the merc 1 pc plate gasket is thick. Honestly Id just get the gasket that goes with your engine serial number and then trim the exhaust outlets if you find that they have been opened up to the hipo motor size...this is the cheaper option and you can't go wrong.
04-16-2021, 11:34 AM #3
he storied ta ya justa little on what it is NOW... its probably loud cause they pulled tha can out and maybe drilled tha down housing...get this one and you'll be fine.
8231422Last edited by tlwjkw; 04-16-2021 at 11:37 AM.
David - WI liked this post
04-16-2021, 11:52 AM #4Junior Member
- Apr 2021
- Michigan
- 18
Thanks bro I really appreciate the link that was really cool of you. Could you point me in the direction of the gasket that goes between the plate and the power head?
04-16-2021, 11:57 AM #5
8231422
part number....
04-16-2021, 12:06 PM #6Junior Member
- Apr 2021
- Michigan
- 18
Same gasket cool thanks man you saved me a lot of time and hassle dealing with my local parts guy
04-16-2021, 12:07 PM #7
ya might try Pro Marine.. may save ya a coupla bucks................
Newer SSM water pump plate gaskets vs older plate gaskets
By Tom Smyth in forum Outboard and Racing HistoryReplies: 3Last Post: 03-24-2014, 08:28 PM -
Powerhead Adaptor plate Gaskets?
By L_Mayne in forum Technical DiscussionReplies: 2Last Post: 10-07-2006, 11:58 AM -
280 adapter plate vs 260 with oval tuner adapter plate?
By rpm racing in forum Technical DiscussionReplies: 0Last Post: 04-25-2005, 10:06 AM
