Results 1 to 10 of 10
04-15-2021, 07:56 AM #1
need a good solution to put an opti away for storage
what's ya best recipe to run thru an opti before a possible long nap .I'd like to preserve the pumps and injectors . thanks , hf...
04-15-2021, 08:47 AM #25000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
You might want to Quiz - Injection Services - Blake he is a member here - off to the left hand side - his advertisement- should get some facts off of him.
Just so your aware - I read that some members add some oil to the fuel and run that in to stop the fuel pumps from sticking - then I thought I read Mercury doesn't recommend putting oil in the cyl plug hole for storage - I thought that was a bulletin , not sure - that is why I thought Blake might be a good solid fact based guy to chat with . Post up what he states as I also run an opti and am going to ask similar questions .Last edited by kellytheaker; 04-15-2021 at 08:52 AM.
04-15-2021, 10:27 AM #3
Merc put some red oily stuff in the fuel when they ran optis at the factory. Don't know what it is but Blake or Chris Carson probably know. Had one sit for 8 years new in box and it started right up. No stuck rings, all pumps operated as they should. I know that isn't too helpful, but if you can figure out what that red stuff is...it works
04-15-2021, 11:55 AM #4
They actually do reccomend (per service manual that is) to put some engine oil in the chambers and rotate by hand. Personally I would use a combo of Quickstore with some 2 stroke oil mised in. Run through a portable tank. I guess it depends on how long your going to be storing it. You could pull the fuel rails and direct injectors off, put some fogging oil in, and re-install the injectors and rails. That would keep the direct injectors from contacting the oil until start up, where it would be burnt off anyhow.
Many ways to skin a cat. The main thing is don't do nothing.
www.InjectorService.com
Call/Text - 204-326-0390
25two.stroke liked this post
04-15-2021, 01:17 PM #55000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
Red oily stuff was probably oil .?
04-15-2021, 01:19 PM #6
04-15-2021, 05:05 PM #7Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Sell it .....store the$$ in bank.... buy 2021 4 stroke 3 years later.......
04-16-2021, 05:52 PM #8
04-16-2021, 07:47 PM #9
Mercury did run engines at the factory on endoline not gasoline . Supposed to be more refined and last longer. Not sure if they do that now . Hf...
Kcraft liked this post
04-16-2021, 09:00 PM #10"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
Solution for propeller storage
By JPEROG in forum General Boating DiscussionReplies: 22Last Post: 09-30-2019, 06:37 AM -
Opti storage. Run the fuel rails dry or leave them full?
By Mr. Demeanor in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 1Last Post: 05-24-2010, 05:31 PM -
250-Opti , How Good Are They ????
By Skater 32 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 11Last Post: 05-24-2007, 03:13 PM -
Opti Plug Fouling Solution
By Ron in forum Technical DiscussionReplies: 0Last Post: 08-12-2002, 04:01 PM
