Results 1 to 2 of 2
    Nov 2012
    New Zealand
    Omc v4/v6 gearcase blend question
    Hi Guys.
    I'm looking at rebuilding my gearbox for racing. I have been hunting through google and cannot find the information. I have the standard v4 gearcase with a 15spline conversion but wondering if the v6 1.86.1 gears fit in? Also if they do is there anything special required to make them fit. I cannot use an actual v6 case as the extra size of it and shaft drop would be too much of a hindrance, but if the gears are interchangeable then I'm keen to build up another case.
    Cheers
    May 2001
    Hickory NC
    No they do not inter change. The 1985 V4 looper had a unit the size of a V6 but with different ratio and drive shaft.
  3. Thanks jrs086 thanked for this post
  1. Replies: 2
    Last Post: 03-11-2013, 04:36 AM
  2. 3l gearcase question.
    By ofna2005 in forum Technical Discussion
    Last Post: 12-10-2011, 01:50 PM
  3. Gearcase question?? 2.4 vs 2.5
    By Vinnie in forum Technical Discussion
    Last Post: 02-15-2008, 01:32 AM
  4. Gearcase question
    By Sorry Dog in forum Technical Discussion
    Last Post: 08-30-2002, 03:54 PM
  5. V6 OMC gearcase question.
    By FCnLa in forum Technical Discussion
    Last Post: 08-06-2001, 07:49 AM
