Results 1 to 11 of 11
    Manchester Iowa
    Transom bolt torque
    Getting ready to bolt my jackplate on my hydrostream any ideas on how much to torque the bolts? Sure don't them to come loose but don't want to crack the fiberglass!
    Plywood core, up to 50 ft. #'s Engine to jackplate 1/2'' bolts 90 lb#s Foam core trans: I am scared to go over 35 ft#'s. Tighten securely and use good nyloc's. Check every few trips for a while to look for any compression if it's a new trans. They don't need to be crazy tight. Just even and secure. Edit.....Use the fine thread bolts too if possible.
    Aug 2012
    Tenkiller Lake, OK
    I recently contacted Skater regarding thru bolt torque for jack plates. 75ft.#.
    Is that jack plate to the hull or plate to engine Tq? Skater does a plywood trans too, right?
    Aug 2012
    Tenkiller Lake, OK
    Jack plate to hull. Yes Skater uses plywood with epoxy/glass over it and paint.
  6. Likes XstreamVking liked this post
    Jun 2018
    Floating around
    me too lol. Thats the only concern I have with the Coosa is crushing it during this process. Still thinking of adding tubes of some kind
    Most people that mount their engines don't use a tq wrench. They use a 8-10''long 3/8'' drive ratchet. Most are torqued far below what they think they are. 35#s on a 1/2'' drive 24'' long handle is a lot of clamping force. Make it as tight as you dare. Stop just before it cracks..Hahaha..
    I used stainless socket head cap screws with the thick stainless ARP washers on both the clamp-to-setback and setback-to-transom connections:
    https://www.allensfasteners.com/deta...roduct_ID=0180
    https://www.allensfasteners.com/deta...uct_ID=22247An
    Inside the boat- stainless fender washers then thick stainless washers, to spread the load:
    https://www.allensfasteners.com/deta...oduct_ID=20223
    https://www.allensfasteners.com/deta...uct_ID=9000012
    Stainless nylocks on all of them:
    https://www.allensfasteners.com/deta...oduct_ID=00089
  10. #9
    That will look real nice.
  11. Thanks David - WI thanked for this post
    Manchester Iowa
    Thanks for all the great information got the plate sealed and torqued last night!
    Apr 2011
    WI
    Had the exact same question this morning for my Checkmate, glad this was right at the top.
    2019 Crestliner 240 Rally DX CWDH Tritoon Merc 200 DTS
    2014 Checkmate 2000 Pulsare BRX Merc 250 Pro XS
    Powerquest 290 Enticer FX Twin 454 Sold
    Hand Built 10ft Aluminum Jet Boat 1500cc Kawi 4stroke Sold
    Playcraft 24ft Tritoon conversion with 235 GT Johnson Sold
  1. Transom bolt torque specs.
    By ctered in forum Props, Setup, and Rigging
    Last Post: 03-29-2007, 09:36 PM
  2. rod bolt torque
    By gonefishing_68 in forum Technical Discussion
    Last Post: 12-09-2005, 03:53 AM
  3. 2.5 R0d Bolt Torque
    By RSM in forum Technical Discussion
    Last Post: 07-02-2003, 04:26 AM
  4. Bolt torque ?
    By gaineso in forum Technical Discussion
    Last Post: 06-13-2003, 05:12 AM
