Results 1 to 11 of 11
Thread: Transom bolt torque
04-08-2021, 06:05 PM #15000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Transom bolt torque
Getting ready to bolt my jackplate on my hydrostream any ideas on how much to torque the bolts? Sure don't them to come loose but don't want to crack the fiberglass!
04-08-2021, 06:51 PM #2Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Plywood core, up to 50 ft. #'s Engine to jackplate 1/2'' bolts 90 lb#s Foam core trans: I am scared to go over 35 ft#'s. Tighten securely and use good nyloc's. Check every few trips for a while to look for any compression if it's a new trans. They don't need to be crazy tight. Just even and secure. Edit.....Use the fine thread bolts too if possible.
04-09-2021, 09:56 AM #3
I recently contacted Skater regarding thru bolt torque for jack plates. 75ft.#.
04-09-2021, 10:01 AM #4Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Is that jack plate to the hull or plate to engine Tq? Skater does a plywood trans too, right?
04-09-2021, 10:03 AM #5
Jack plate to hull. Yes Skater uses plywood with epoxy/glass over it and paint.
XstreamVking liked this post
04-09-2021, 11:51 AM #6
04-09-2021, 12:04 PM #7Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Most people that mount their engines don't use a tq wrench. They use a 8-10''long 3/8'' drive ratchet. Most are torqued far below what they think they are. 35#s on a 1/2'' drive 24'' long handle is a lot of clamping force. Make it as tight as you dare. Stop just before it cracks..Hahaha..
04-09-2021, 01:02 PM #8
I used stainless socket head cap screws with the thick stainless ARP washers on both the clamp-to-setback and setback-to-transom connections:
https://www.allensfasteners.com/deta...roduct_ID=0180
https://www.allensfasteners.com/deta...uct_ID=22247An
Inside the boat- stainless fender washers then thick stainless washers, to spread the load:
https://www.allensfasteners.com/deta...oduct_ID=20223
https://www.allensfasteners.com/deta...uct_ID=9000012
Stainless nylocks on all of them:
https://www.allensfasteners.com/deta...oduct_ID=00089
04-09-2021, 02:41 PM #9Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
That will look real nice.
David - WI thanked for this post
04-10-2021, 04:28 AM #105000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Thanks for all the great information got the plate sealed and torqued last night!
04-15-2021, 08:21 AM #11Member
- Apr 2011
- WI
- 42
Had the exact same question this morning for my Checkmate, glad this was right at the top.
2019 Crestliner 240 Rally DX CWDH Tritoon Merc 200 DTS
2014 Checkmate 2000 Pulsare BRX Merc 250 Pro XS
Powerquest 290 Enticer FX Twin 454 Sold
Hand Built 10ft Aluminum Jet Boat 1500cc Kawi 4stroke Sold
Playcraft 24ft Tritoon conversion with 235 GT Johnson Sold
Transom bolt torque specs.
By ctered in forum Props, Setup, and RiggingReplies: 8Last Post: 03-29-2007, 09:36 PM -
rod bolt torque
By gonefishing_68 in forum Technical DiscussionReplies: 22Last Post: 12-09-2005, 03:53 AM -
2.5 R0d Bolt Torque
By RSM in forum Technical DiscussionReplies: 19Last Post: 07-02-2003, 04:26 AM -
Bolt torque ?
By gaineso in forum Technical DiscussionReplies: 5Last Post: 06-13-2003, 05:12 AM
