Results 16 to 30 of 42
Thread: Tuff 28 w/2X300R
04-09-2021, 10:23 PM #165000 RPM
- Jan 2021
- Lake Muskoka,Ontario
- 171
- 10
- 58
Instigator, John S liked this post
04-10-2021, 07:55 AM #17
04-10-2021, 08:52 AM #185000 RPM
- Jan 2021
- 171
- 10
- 58
Kcraft liked this post
04-10-2021, 05:46 PM #19Team Member
- Lake Coochiching, Ontario
- 7,756
- 272
- 485
- 1577
- 6 Post(s)
Ballast tanks add weight which improves the ride in rough water. I use passengers for ballast. A ballast tank can also alter the CGwhich can be beneficial
Of course the most common ballast tank application is to create big wakesLast edited by David; 04-11-2021 at 08:27 PM.
04-13-2021, 01:04 AM #20
Mine was alot heavier and still ran 101 with 300XS motors. I had it in a big lake with 2.5ft white caps and was running 98 with one hand on the wheel. The guy I sold it to said he could run 70-75 in 3 footers in the ocean and was very smooth. I'm sure the heavier weight helped. It was a 2700 lb bare hull. It was without doubt the best driving V-bottom I've eve driven regardless of size.
Boat Delivery available
Things owned. NOTHING!!
Just Tool'in thanked for this post
04-13-2021, 08:01 AM #21
Great to hear real world perspective, and from someone that has a ton of experience running different hulls! Thanks Randy!
04-13-2021, 09:51 AM #22
the ballast tank allows you to keep the boat balanced, the fuel weight is in the center of mass, as you consume fuel it doesn’t change the balance of the boat. It makes it lighter, but not unbalanced. The comments about calm water are uneducated. Forward entry, dead rise and length are the key rough water ability. Low profile and stern keel don’t effect how they operate in adverse conditions. It is a poor misconception that freeboard or full length vee make for better rough water running. In the rough you use the bow section to deflect the water laterally. Freeboard doesn’t have any effect, nor does the pad at the stern. The Tuff is a deep vee, with narrow forward entry allowing it it swing way above its weight.
This red 28, is a full weight 110 mph monster. Add ballast will allow for big water running. Remove the weight and stand it on its tail like tuffs are know for and it will run big numbers.
The rest of the comments about it being a calm water boat belong on CNN2023 TUFF 25
HydroSkreamin, Toffen, blkmtrfan, TooStroked, Charli, Speed Jr., bpribyl1, Kcraft, Instigator, WavetoWave liked this post
04-13-2021, 05:06 PM #235000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 708
- 50
- 42
- 199
- 210
Kcraft, Instigator liked this post
04-14-2021, 09:20 AM #24
Forgive me if I find it bit hard to believe a 28 v-hull will run faster than a 28 Skater with the same power. 28 Skater with 300xs has a hard time getting to 118 mph.
Beak Boater, Hayabusajm liked this post
04-14-2021, 10:59 AM #255000 RPM
- Dec 2019
- Spring Lake MI
- 494
- 38
- 154
- 448
The blue 28 did a number on the Skaters at the Lotto shoot out a couple of years ago so believe it.
TJ @ Baker Engineering
Tuff 24 300xs
Tuff 16 90 Yammie
3.75@199mph with LSX power!!!
Instigator thanked for this postInstigator liked this post
04-14-2021, 11:13 AM #26
Beak Boater liked this post
04-14-2021, 11:49 AM #27
Tuff now has Hyperbolic thrusters.
04-14-2021, 12:58 PM #28
04-14-2021, 04:53 PM #29
Tuff 28
04-14-2021, 04:55 PM #30
TUFF n' UFF ?
By Fullthrottleguy in forum General Boating DiscussionReplies: 41Last Post: 04-14-2021, 07:50 PM -
Are you tuff enough?
By XstreamVking in forum The Scream And Fly LoungeReplies: 7Last Post: 08-02-2020, 09:20 PM -
Tuff 21
By Greg G in forum General Boating DiscussionReplies: 63Last Post: 03-26-2017, 08:27 AM -
Tuff 21 Pix?
By SCT in forum General Boating DiscussionReplies: 225Last Post: 11-08-2014, 03:20 PM -
Tuff 16
By David in forum General Boating DiscussionReplies: 30Last Post: 08-29-2009, 08:17 AM
