Results 1 to 5 of 5
Thread: broken 2.5 LU
    Jan 2005
    New York
    broken 2.5 LU
    can i ru a sport master that lost the tail? It broke off at the zink . I dont know how , maybe hit something in the water. 5 out of 6 bolts but no tail section.
    What do you guys think. skag and the rest of the unit is fine. CRAZy
    Patriot Missile
    Jan 2020
    Pinole, Ca
    How high you running it? If you are worried about the structural integrity you are fine. The back side of the unit is in compression most of the time so running without that bolt is OK. I would be more worried about stress cracks other places in the unit that you may not see (since you hit somethin somehow). I would think its safe to run now until you see cracks form somewhere else.
    I would suggest buyin a donor unit at some time and having the sporty fixed. I think the tail end of all the units is the same if I'm not mistaken. And if thats the case I got one I can probably send you a piece of and find a good merc welder to put it back on for you.
    Jan 2005
    New York
    Im running even on pad. Im back 12 " . I must have hit a crab cage going very fast. It wrecked the prop and snapped off the tail . It snapped off at the end of the zink hole. Why they put a zink there IDK. Who the hell needs a zink there? It made it so weak. I was wondering ,what does that tail do anyways.
    Patriot Missile
    Jan 2020
    Pinole, Ca
    I mean...in a surfacing application it does nothing except kick down some spray.
    Pekin, IL
    Sportmasters sometimes break there for some reason. We lost one without hitting anything. Snapped at the zincs.
    Rock
    Team Junk
  1. broken bow
    By spunkydunky1974 in forum Upcoming Events, Races, and Gatherings
    Last Post: 06-15-2009, 06:28 AM
  2. broken stud...need help
    By KWACTION in forum Technical Discussion
    Last Post: 05-24-2007, 01:07 PM
  3. broken top end cap
    By concord in forum Technical Discussion
    Last Post: 03-15-2007, 05:33 PM
  4. Broken tap
    By Steve Reist in forum Technical Discussion
    Last Post: 06-07-2003, 11:46 AM
  5. broken rod!
    By vishus in forum Technical Discussion
    Last Post: 04-21-2003, 09:20 PM
