Results 1 to 9 of 9
Thread: Shift cable retainer?
04-06-2021, 09:54 AM #16000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Looking for a little help. I removed an old style mercury control box with the combo throttle, shift, key switch and installed a Hardin Marine shift lever. The shift cable on the lever end has the black plastic cylinder on it to lock the cable housing in place. Anybody know a part available to retrofit something to hold the cable housing in place?
I've also seen cables with a groove in the housing end that a clamp can go over and hold the housing from moving. Sort of a flat piece of metal with a half circle in it that screws over the cable housing to lock it in place.
My housing is smooth other than the black plastic cylinder. Hot Foots have a similar mount where the plastic cylinder slides in then a cotter pin holds it in place.
I know I can change out the cable to one with the groove in the housing but I'd rather find a part to make this work. Thanks.Bullet CC w/ 225 Promax - Sold
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
04-06-2021, 10:07 AM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
04-06-2021, 10:10 AM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
...gots ta git da otha style cabel & git da ad-on barrl kit fer dat cabel...
04-06-2021, 10:36 AM #46000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Thanks guys. I have a piece of aluminum square bar. Think I'll try to fab something. Drill a hole in end and cut a slot for the housing. See if that works out.
Blazer 650 Pro Tour
04-06-2021, 10:39 AM #5
04-06-2021, 10:45 AM #6
The Hardin Marine N control shifter takes a gen 2, as it only has a metal U clip to hold in the cable.
https://www.hardin-marine.com/p-1360...t-shifter.aspx
However, Hardin sells a gen 1 cable attachment kit that mounts with 1 screw, you gotta see if your box can accept that screw.
https://www.hardin-marine.com/p-35541-mercury-cable-attachment-for-n-control-shifter.aspx
DangerNewb thanked for this post
04-06-2021, 10:52 AM #76000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
I bought this one so there's no cable mount provided. My cable is Gen 1. I think I can fab something to work. Thanks for the input.
Blazer 650 Pro Tour
04-06-2021, 10:56 AM #86000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Closer look, yes that little adapter from N Control would probably work. I'd just need a longer screw. This is mounted to a piece of maybe 3/8 wood that's been glassed over like you see in STV Pro Comps.
Blazer 650 Pro Tour
04-16-2021, 02:19 PM #9
I had the same issue bought a Rex shifter from a member on here. I fabricated out of a piece of thick plastic drill the hole for the barrel to be inserted and put a clamp right behind it. Worked fine for me but only had it installed for one season so far
1986 cougar mtr 21
2003 supra launch ssv
OMC Tech: Shift rod retainer bolt broken
By rochelle howell in forum Technical DiscussionReplies: 11Last Post: 10-19-2016, 11:20 PM -
Mercury Tech: 2000-2001 Mefrcury Promax 225 bottom cowl cable retainer
By Air Ride in forum Technical DiscussionReplies: 0Last Post: 08-19-2013, 08:02 PM -
Billet Shifter Merc cable retainer - where??
By Fliperzon in forum Props, Setup, and RiggingReplies: 4Last Post: 07-21-2007, 11:36 AM -
Please Help! Shift Cable ?
By Rocco in forum Technical DiscussionReplies: 2Last Post: 05-29-2005, 11:42 AM
