Results 1 to 6 of 6
    Nov 2020
    Nj
    Narrowing prop choices down for my checkmate predictor need help getting it stable
    Currently I'm running a 13/21 Michigan wheel Apollo the speed is good 55-58 mph depending on the load and if you can hold it,wants to chine walk bad and steering is horrible I'm currently looking at a Michigan wheel ballistic in either a 13-1/4x 21 or a 13-1/2x22 which I feel will be alittle too much prop also the laser II small hub on these same sizes any help would be greatly appreciated
    Manchester Iowa
    What type of steering are you running? Hopefully at least dual cable not the no feedback I like hydraulic best is your engine height to low? Do you have a torque tab on the skeg? Proper setup is everything
  3. Likes David - WI liked this post
    Check the motor mounts & steering... balance the weight in the boat left/right.
    Nov 2020
    Nj
    Quote Originally Posted by Merc Speed View Post
    hydraulic steering, I brought the motor up two holes but it's still 4-4.5 inches below the pad so I will be getting a jack plate. No torque tab.
    Lake Coochiching, Ontario
    I used to have a 16 foot Baja and it would chine walk at 60. Practice. What V hull does not chinewalk? A slow one.
  7. Likes LakeFever, 25two.stroke liked this post
    Feb 2005
    seattle
    to run in the upper 60 and 70 you'll need to be 1" below the pad. dont go for a 4 blade prop. the transom lift of the 4 blade will lift the whole boat out of the water.
  1. Checkmate predictor with 115 merc i6 prop recommendations
    By Check82 in forum Props, Setup, and Rigging
    Last Post: 04-01-2021, 06:59 PM
  2. 79 checkmate predictor
    By Merc 2.5 in forum Boat Build-Ups and Restorations
    Last Post: 10-27-2019, 01:14 PM
  3. 78 checkmate predictor w/ 89 johnson 140 looper-prop?
    By Boatboylll in forum Props, Setup, and Rigging
    Last Post: 11-19-2012, 07:42 AM
  4. 16ft checkmate predictor prop?
    By gusmoyer11 in forum Props, Setup, and Rigging
    Last Post: 07-15-2011, 07:41 PM
  5. Checkmate Predictor Help
    By kalugs22 in forum Props, Setup, and Rigging
    Last Post: 09-09-2009, 11:25 AM
