Results 1 to 6 of 6
Thread: CRT piston rings??
04-05-2021, 10:38 AM #1
CRT piston rings??
What piston rings should be used in CRT pistons (steel bore)
thanks, NelsonLast edited by nelson edens; 04-06-2021 at 07:02 AM.
death is certain; life is not
04-06-2021, 05:39 AM #2
Nelson the CRT pistons use mercury rings.
04-08-2021, 09:36 PM #35000 RPM
- Jun 2014
- United States
- 153
- 7
- 30
- 42
Nelson, I have been using a set of rings on my CRT pistons for a year and a half in my steel bore motor. You need to contact Dean Pink at Wizard. He has what you need. I promise this is the way to go.
04-09-2021, 01:41 PM #4
thanks Bud. I confirmed that the Mercury rings fit. The Wizard rings do NOT fit. I have some of both. I am actually using PRO Marine 481 rings (steel sleeve motor) modified to fit the top pinned CRTs.
04-09-2021, 02:04 PM #5Bud Conner "Heathen" "Defending Our Constitution"
04-09-2021, 09:12 PM #65000 RPM
- Jun 2014
- United States
- 153
- 7
- 30
- 42
If you contact Dean, he has the correct rings. He has different pistons with different grooves.
OMC Tech: Which piston rings to use?
By HydraSport179V in forum Technical DiscussionReplies: 28Last Post: 12-05-2011, 09:22 AM -
Piston Rings
By mrbim in forum Technical DiscussionReplies: 1Last Post: 12-28-2001, 06:55 PM -
piston rings & crank sealing rings
By TB21 in forum Technical DiscussionReplies: 13Last Post: 12-19-2001, 08:49 PM
