Results 1 to 2 of 2
    Aug 2009
    Somewhere
    L/R 1.62 sportys converted for evinrude etec G1
    I got 2 Mercury 1.62 sportys L/R that are converted to fit directly onto evinrude etec mid/motor. Fat shaft prop shafts (brand new prop shaft in RH hand, bearings and seals ), Billet multi seal carrier for drive shafts, shift and prop shafts(anodized blue prop shaft carriers) . Comes with modified shift rod to make it all work properly .They used factory evinrude etec waterpumps. 20"mid setup
    Lowers are located in Tarpon Springs, Fl
    Asking $8500 obo for both
    Was for a project but going a different direction
    (Also have for the same motors available solid upper and lower mounts and a steering setup with custom wingplates, tilt pins , steering rams and tie bar available at additional cost)
    Sep 2007
    Peterborough, Canada
    PM Sent
  1. evinrude etec 250HO
    By rubenruiz17 in forum General Boating Discussion
    Last Post: 04-11-2016, 03:42 AM
  2. Evinrude Etec 150 HO
    By jonp in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 11-02-2010, 04:06 PM
  3. Evinrude 150 ETEC reliability?
    By stv1991 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 06-14-2010, 11:15 AM
  4. Evinrude Etec Help
    By DANIELNSRI in forum General Boating Discussion
    Last Post: 06-25-2006, 11:36 PM
