Results 1 to 15 of 25
Thread: Mercury 175 starts and stalls
03-22-2021, 04:59 PM #1Member
- Feb 2005
- Rehoboth, Ma
- 41
1998 mercury 175hp Xr2 sportjet starts and stalls
I am trying to run my power head on my work bench, the stator, trigger, rectifier and switch boxes have been replaced, the electric fuel pump and pulse fuel pump are good. The motor starts when I spray fuel into the carbs but oily runs for a couple seconds- any ideas..?
Also how do I set timing and are there any adjustments to the Arm that the trigger is attached to?
03-22-2021, 07:14 PM #25000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Is you enricher working? How are your carbs?
03-23-2021, 10:09 AM #3Member
- Feb 2005
- Rehoboth, Ma
- 41
03-23-2021, 10:39 AM #4
If it runs when you spray fuel in then obviously the timing is close enough for it to run... you need to figure out why it's not getting any fuel first.
03-23-2021, 05:05 PM #5
open up your carb drains and see if there is any fuel in them
03-23-2021, 06:37 PM #65000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
A properly working enricher goes a long way to starting a cold engine.
03-24-2021, 08:04 AM #7Member
- Feb 2005
- Rehoboth, Ma
- 41
I open the carb drains the bowls have fuel, I can hear them fillinf when i pump the fuel bulb on the remote tank, How do I test the enricher?
03-24-2021, 06:31 PM #85000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
03-25-2021, 07:50 AM #9Member
- Feb 2005
- Rehoboth, Ma
- 41
Glastron - I have the powerhead on my work bench (no key switch) using remote starter off solenoid.
Q: in the manual it says to adjust the screw in yellow for full throttle stop is that correct , or should it be the one circle in red that one closed the gap between b and C
The Maximum Timing Adjustment also calls this screw (b) (Same as Above) to be adjusted to obtain 22btdc, I am getting 16 Atdc.Last edited by dave22; 03-25-2021 at 08:03 AM.
03-25-2021, 11:26 AM #10
Loosen nut and back screw out till you see 22.
RockTeam Junk
03-25-2021, 03:34 PM #11Member
- Feb 2005
- Rehoboth, Ma
- 41
cannot get there even when back off all the way
03-25-2021, 04:34 PM #12
When installing stator is it possible a screw too long was put in a spot that would limit trigger travel?
RockTeam Junk
03-25-2021, 06:18 PM #13Member
- Feb 2005
- Rehoboth, Ma
- 41
No use same hardware same location.
Enriched works when I manually press the top dome I get fuel from the 3 lines
03-26-2021, 05:26 PM #14Member
- Feb 2005
- Rehoboth, Ma
- 41
Ok finally got to timing to 20 btdc runs a few seconds longer, getting plenty fuel from pump, looking like carb issue .
Had to remove stator and trigger when reinstall was able to set wot timing.
03-30-2021, 06:25 PM #15Member
- Feb 2005
- Rehoboth, Ma
- 41
Anyone from the Massachusetts area who can take a look at this will pay for your time
1998 sportjet starts and stalls
By dave22 in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 03-14-2021, 08:14 AM -
OMC Tech: 2000 Ficht 150 starts and stalls immediately. Bad ECM?
By crmach1 in forum Technical DiscussionReplies: 0Last Post: 06-23-2013, 07:29 AM -
75 FICHT starts and stalls
By pointer in forum Technical DiscussionReplies: 10Last Post: 08-27-2012, 06:14 AM
