Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
    WI
    Any pics of the chip box???
    I have a boat or two.... that I never get to drive
  2. #17
    WI
    11350a??
  3. #18
    Jan 2020
    Pittsburg, Ca
    Not sure. I have a 2.4 chip in it now and I plug a DDT into it and read all the parameters. I got it from a guy who was runnin it on a 2.5 and he kept that 2.5 chip...don't think its a merc box
  4. #19
    Nov 2021
    Holland,Michigan
    Need a exhaust divider for 175 2.5 it's a 1994 block has no serial number.
    1988 Bass Tracker 1800FS Tournament W/ Mercury 150 BlackMax 2.0
  5. #20
    WI
    That is a CDI aftermarket box. Not sure what chips work in it, whether Merc and CDI, or just CDI. The chip determines the curve and the fuel pressure of which the curve is built for. Won't work for my buddy but it should be fine for someone that has a comparable engine to yours. Sorry, I never received an email of the updates you posted.
  6. #21
    Jan 2020
    Pittsburg, Ca
    Quote Originally Posted by SJD1974 View Post
    I do have a divider if you need one.
  7. #22
    Nov 2021
    Holland,Michigan
    What do you need for it?
    For a 2400lb fishing boat. Goal to run 6500, that's getting heads cut for 140 comp, stuffers, cc reeds and running WMV 18 carbs if possible. Will this chest work and rod slot area be ok. Did we work enough out or should we do more. Hopefully we didn't take out to much. This is the same motor that I need the exhaust divider for. Is there anywhere else stuffing can be put? Sorry going off track.
ID:	539685Click image for larger version.
ID:	539686Click image for larger version.
  8. #23
    Jan 2020
    Pittsburg, Ca
    Rod slots can be cut more. Exhaust leave as is. Yeah I got a divider for you, I'll get it from my storage tonight.
  9. #24
    Austin Tx
    Exhaust chest work looks the coolest and does the least. Stick with compression, Intake work and set up. If you have the stock constant diameter tuner, get rid of it and at the very least put a 2.4 tuner on it. Good props, engine height and a diet, will net you the most...
  10. Likes Baker343 liked this post
  11. #25
    Nov 2021
    Holland,Michigan
    Thanks for your help.
    First time working on 2.5.
  12. #26
    Jan 2020
    Pittsburg, Ca
    I got that divider in my car with me if you still need it.
