Results 31 to 37 of 37
Thread: Glastron CVX20 Project
04-21-2021, 09:40 PM #31
Check out Ron's build on his Glastron. He added a pad and runs it with a 2.5 Merc. Page two outlines how he added the pad.
https://www.hydrostreamforums.com/vi...php?f=6&t=3609
And another picture of a pad hull.
04-22-2021, 04:51 AM #32Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Cool project you have going. Here is the pad I added to a 17' V, it might help you. Dead flat raised pad as opposed to a delta pad approach.
04-22-2021, 05:19 AM #33Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
And here is the pad on another boat I have a 23 footer. In my opinion, if your hull is going to be multi-use and your glass man is masterful, I'd strongly suggest you add a couple of degrees of deadrise in any raised pad you settle on to make it a bit more forgiving.
04-22-2021, 01:44 PM #34
Wow, great great replies, thanks a million. I have a pretty good idea of how to solve this pad.
Question two: The 27 gallon fuel tank was located up front under the deck and I'm sure that's great for skiing, but not sure if its good for stability at high speed. 27 gallon is far from enough for a Monty motor and I am playing with the idea of using two tanks in the rear instead. Opinions?True Viking
Scarab 34 SS with Triple OMC 4.0 V8's
04-22-2021, 03:49 PM #35
That's alot of weight
Azure AZ259, 8.1
04-26-2021, 07:55 AM #366000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
Cool project !
I'm doing a structural restoration on a 21 Checkmate Starflite that may get one of my V8s so I'm looking at many of the same issues.
I'm leaning towards a supplemental belly tank that would be used when the extra range is needed (which might be most of the time lol). I plan to have a small transfer pump to fill the main tank from the belly tank. I don't mind losing my in-floor ski locker, not sure if the CVX-20 had one or not.
Matt
kimswang liked this post
04-28-2021, 05:35 PM #37
Thank you Sir!. The fuel tank issues has been solved if I can get the welder to do it. Two saddle tanks in the back with a 4" pipe welded in between them will fulfill the requirement of the coastguard. The knees that I am putting in made out of coosa will prevent any other option, but I think the pipe will do. I will then move 3 34 size batteries up to the front and we should be all good weight wise. I have decided to make the pad 16" wide, and 7' long. It should give the boat the ability to run with the best as well as continuing to be a nice ski boat with the keel it has forward.
True Viking
new boat new project, 70s glastron/carlson 15'
By Steel_drifter in forum Fiberglass and Composites DiscussionReplies: 10Last Post: 05-14-2016, 07:04 AM -
New to me Glastron CVX20
By Glastron200 in forum General Boating DiscussionReplies: 26Last Post: 07-17-2012, 09:38 PM -
Glastron CVX20 as a Bay Boat in Miami?
By maineidyl in forum General Boating DiscussionReplies: 6Last Post: 11-04-2011, 11:52 PM -
Glastron CVX20 Timing/Carb Questions
By shotguntoo in forum Jet Boats, V-Drives and Stern DrivesReplies: 1Last Post: 05-07-2009, 07:36 PM -
Input on 1979 Glastron CVX20
By VernG in forum Jet Boats, V-Drives and Stern DrivesReplies: 10Last Post: 11-06-2008, 01:55 AM
