Results 16 to 22 of 22
04-15-2021, 10:22 AM #168' Yellow Jacket - 25 hp Mariner
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
04-15-2021, 08:52 PM #17Member
- Jun 2020
- Toronto
- 63
I can't remember the name of the screw I turned down to allow the throttle to idle down a bit. I will post back when i look at the manual at home thanks.
04-15-2021, 09:19 PM #18
tha small 10/32 screw with loc nut is tha "ONLY" thing ya turn to adjust idle speed/rpm.. NOTHING ELSE
04-17-2021, 07:19 PM #19Member
- Jun 2020
- Toronto
- 63
I turned that smaller screw to set the static timing at 8 degrees after tdc. I turned the bottom one to lower the idle
04-17-2021, 08:01 PM #20
"SMALLER SCREW".....That is tha ONLY screw ya turn ta do anything ta raise or lower idle speed and/or rpm.. no other screw needs ta be touched.....
idle timing numbers don't mater.. put tha rig in tha lake, in gear ta get what ya want for "idle"... you won't even need a timing light.. set it (with idle timing screw ONLY) IN THA WATER, IN GEAR TA WHATEVER MAKES YOU AND THA MOTOR HAPPY.. forget tha numbers..
04-18-2021, 06:37 AM #21Member
- Jun 2020
- Toronto
- 63
Ok I will try it all again just to be sure. When I was trying to set the total timing while cranking my timing light wouldn't even flash. I think my battery is getting weak so i'm going to replace it with a 1000 CCA one and try to set it all up again. Right now though it does appear to be running well. Thanks
04-18-2021, 06:41 AM #22
now you do need to use light to set MAX timing at crankin' speed with all plugs removed but grounded...
remooving low speed/high speed spark advence module
By jmr112 in forum Technical DiscussionReplies: 15Last Post: 12-14-2016, 10:46 PM -
trouble getting from idle or off plane to high speed
By capnzee in forum Technical DiscussionReplies: 12Last Post: 07-10-2014, 07:59 PM -
Mercury Tech: 2.5 Remove high and low speed stabilizer boxes??
By cheapbeater in forum Technical DiscussionReplies: 5Last Post: 05-25-2009, 03:20 PM -
idle stabalizer or low/high speed advance
By RSM in forum Technical DiscussionReplies: 0Last Post: 07-09-2003, 01:33 PM -
V-4 making snorting noise at idle after extended high speed runs
By Ron V in forum Technical DiscussionReplies: 15Last Post: 04-05-2002, 08:46 AM
