Results 1 to 7 of 7
    Dec 2011
    St. Pete, Fl
    Jackplate goes up, but not down- help!
    I have a Bob's jackplate that will go up, but when you push the down button, nothing happens. Won't go down. Any thoughts? I was thinking the up/down switch might be bad. I've heard of relays/solenoid maybe going bad... Don't any any idea how to fix if it's a relay/solenoid.. Hopefully just a switch, they're cheap ($25) and easy to fix. Any help/stories with prior experience with this issue is appreciated.
    thanks,
    Brian
    24 Spectre 250 XS
    19 Reaction 150 Pro XS
    21 Checkmate 250 Pro XB (sold)
    25 Talon Carrier (sold)
    24 Predator 300x (sold)
    21 Talon 225 3.0 liter (sold)
    18 Talon 2.4 Bridgeport (sold)
    Sep 2017
    ontario
    check with a test light to see if it is getting power - then listen for a relay or solonoid click . and then you will know better but if getting power - relay - solonoid - switch them around and see if that improved situation . check connections at dash and pump , fuses - all the simple stuff first - that should get you started - hope this helps
  3. Likes XstreamVking, rock liked this post
    Aylesford Lake,NS Can.
    Bklingel418
    A quick test for the solenoid would be to pit a jumper wire to the two large posts on the down solenoid to see if it moves then. That will eliminate the solenoid. If it is an older plate then it has the smaller solenoids. I upgrade mine last year to the larger ones which Bob's offer on their website. I hope this helps.
    Thanks
    Gary
    If it's a bobs the relays are usually mounted on the pump bracket. If the relay is getting power but not working just call bobs and get 2 new ones. Replace them both and just remove and replace the wires as you go. Or take pics to guide you on rewiring them. It's not hard. Just get a cheap multi voltester ot a light at least.
    Sep 2016
    McHenry,Illinois
    If the pump is a 2 wire pump it needs both relays for both up and down....best to change both at the same time. If it's a three wire pump it could be just the down relay. With the three wire pump relay ...yes you can jump across the 2 large posts to check...not so on the 2 wire pump relays.
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork (Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Ranger 17' Aztec / Merc 115
    Hustler 16' Victor
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel / Johnson GT115 (current project)
    Hustler 16' Victor
    Dec 2011
    St. Pete, Fl
    Quote Originally Posted by Hydrogasm View Post
    Bklingel418
    Thanks
    Gary
    Can you do this with a screwdriver? I've seen my buddy put his Port-a-bracket up & down with a screwdriver on the pump. It zaps a little, but works. So if it works with putting the screwdriver on it, then it's a bad solenoid & needs to be replaced?
    Brian
    24 Spectre 250 XS
    Better to use a voltmeter or a test light. Sparks in a boat is a bozo no-no. Hate to see you splode it. Battery fumes and gas is near, and it's a closed compartment.
  1. Replies: 7
    Last Post: 12-22-2010, 12:21 AM
  2. To jackplate or not to jackplate a V-King
    By jlittle in forum Props, Setup, and Rigging
    Last Post: 10-03-2003, 05:11 PM
