Results 1 to 9 of 9
    Feb 2021
    MS
    1985 Mercury XR2 150 water pump base
    Need help. Canít find correct water pump base for xr2 150. I need one with a dowel hole in the bottom. I purchased a 46-96418A kit, which is number on upper portion of pump housing. It did not include seal for base, which I need.I then ordered a base according to chart on internet. It is 46-8M0077147. It does not have dowel hole in bottom. No number on old base. Any help is appreciated.
    TX......somewhere?
    should be #96146A6
    Feb 2021
    MS
    should be #96146A6
    Do you think it is possible part of base stuck in gear case ?
    96-146A6 does not look like base I removed, best I can tell in pictures. I read an old thread and it stated only part of pump base came out, it mentioned the dowel hole I was talking about. Do any pump bases have a hole for dowel pin ? Thanks for help.
    TX......somewhere?
    "Do you think it is possible part of base stuck in gear case ?"
    sometimes that does happen....
    is it a pre-load case?..
    is 24A tha dowl ya talkin' 'bout?
    GEAR HOUSING(DRIVESHAFT)(WITHOUT A DRIVESHAFT NUT) - 1985 Mercury Outboard 150XR2 [ELPTO] 1150765 | Crowley Marine
    Feb 2021
    MS
    First off, thanks for the help. I am not familiar with all the terms, so excuse my bad descriptions. I believe what has happened is when I removed water pump base, that the bottom in which the large oil seal is in, stuck to the driveshaft and pulled out of pump base. Therefore leaving a piece which I thought stayed on drive shaft just above bearing in place, which had a dowel or pin sticking up like the ones on top side of base. I will take it apart and take pictures and post when I can. It is a ez-shift pre-load type with driveshaft nut. As you can tell, not a mechanic but like to fix my own stuff and learn how it works. May come in handy with a 30+ year old Merc. Thanks again.
    TX......somewhere?
    sometimes tha bottom piece (part with big o-ring) will break off tha base when ya pry tha base out.. sometimes so clean it looks ta be two separate pieces.. if your case is tha pre-load it will not have tha drive shaft nut.. does tha drive shaft have a small pin sticking out tha top?.. if so you need tha base in tha diagram/parts list in tha link posted............
    Feb 2021
    MS
    It does have the small pin on top of driveshaft. It has drive shaft nut on pinion gear. I think you are exactly right about base coming apart. I have pump ordered. Will see if that is what is going on when I tear it down.
    TX......somewhere?
    Quote Originally Posted by Phillip P View Post
    its referin' ta tha nut that holds top drive shaft bearin' in place.. Thats one of tha things that changed when tha pre-load case went away...
  9. Likes 25two.stroke liked this post
  10. #9
    Feb 2021
    MS
    What I thought happened, did happen. Bottom of wp base stuck to driveshaft. Removed it and part # 96-146A6, as suggested, fit. Thanks for the help
  1. 99 mercury xr6 water pump base question
    By Keither1984 in forum Technical Discussion
    Last Post: 06-29-2020, 08:26 PM
  2. identify this water pump base
    By redemn93 in forum Technical Discussion
    Last Post: 04-06-2014, 03:04 PM
  3. Mercury Tech: water pump base
    By mariner200 in forum Technical Discussion
    Last Post: 08-04-2009, 10:04 AM
  4. water pump base?
    By keeper in forum Technical Discussion
    Last Post: 12-27-2006, 11:44 AM
