Results 1 to 6 of 6
Thread: 2.5 Crank
03-06-2021, 08:42 PM #15000 RPM
- Feb 2020
- MinneSnowda
- 346
- 27
- 102
- 28
2.5 Crank
Hey Folks
I picked up a 2.5 that I found the number 1 cylinder head gasket blown. There was some pitting and on the cylinder below it I saw some scoring, but nothing I could feel with my finger or finger nail.
No biggie, new gaskets, hone and re-ring.
Well... I got it disassembled tonight.
Apparently this thing sat and the crank shows some signs of damage.
On the good side... it has the plastic bearing retainers, so I need to order the steel style bearings... and due to the scoring, it probably would be good to go .010 over. The rebuild kit I found has the pistons and metal caged bearings... so that's good...
BUT that crank... oof. I'm really hoping I don't need to try and track down a crank.
(For some reason it's not letting me attach pictures right now. I'll try in another post)
03-06-2021, 09:08 PM #25000 RPM
- Feb 2020
- MinneSnowda
- 346
- 27
- 102
- 28
03-06-2021, 09:15 PM #35000 RPM
- Feb 2020
- MinneSnowda
- 346
- 27
- 102
- 28
03-06-2021, 09:32 PM #4Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
its called bearing etch and most likely wont last very long if at all
DieselDood liked this post
03-06-2021, 09:44 PM #55000 RPM
- Feb 2020
- MinneSnowda
- 346
- 27
- 102
- 28
03-07-2021, 12:04 AM #6Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Hone the clys.....replace crank and bad rods....
New Big bearing 2.5 crank (not a 260 style crank)
By GILMORE010 in forum Misc. Parts and AccessoriesReplies: 2Last Post: 02-24-2016, 03:32 PM -
drag crank,has a coller or spacer between bearing and crank is this normal?????
By camaro7081 in forum Technical DiscussionReplies: 29Last Post: 10-22-2009, 09:42 PM -
what is the difference from a 260 crank to a fishing motor crank
By camaro7081 in forum Technical DiscussionReplies: 21Last Post: 02-14-2007, 08:20 PM -
Top Main Crank Bearing/ Rod To Crank Bearings
By mr twister in forum Technical DiscussionReplies: 2Last Post: 09-09-2003, 08:45 AM
