Results 1 to 3 of 3
    Feb 2020
    MinneSnowda
    Electric pump, regulation and fuel/water filtration
    Hey guys
    It seems like every time I'm here I write a novel.
    Sorry.
    I've got an old 184 Champion. It has/had a 150hp OMC on it. The fuel pump failed and I couldn't get the rebuild kit before a tourney, so I installed a 73gph 4-7psi Electric. (tied into the kill so it also shuts down when the tether is pulled... before anyone jumps on that)
    That motor has worked ok for me, but I haven't been overly happy with the performance.
    So I invested in a 175hp 2.5L Mercury. I'm going to go through and freshen it up before I install it.
    I was reading the spec for the Merc is 4.5psi. The OMC was 7.
    Ok, I can add a fuel pressure regulator. Reading about them, the Non return style are cheaper, but aren't as good as the return style
    The OMC had virtually no fuel filtration, so I added cute little filter.
    I was looking at a Spin on style shown in the link below.
    On that housing it shows 2 inlets and 2 outlets.
    If I get a fuel pressure regulator that has a return, can I return fuel to the other Inlet of that fuel filter housing?
    Thanks
    https://www.cabelas.com/shop/en/bass...E&gclsrc=aw.ds
    Non-return regulators work fine on carburated engines. There's no fuel pressure in the float bowls.
  3. Likes DieselDood liked this post
    Feb 2020
    MinneSnowda
    Works for me. Thanks!
  1. Electric water pump on v-drive
    By bad_behavior in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 06-04-2008, 09:28 PM
  2. Replies: 6
    Last Post: 05-12-2005, 02:21 PM
  3. electric fuel pump, through factory pump, or by pass?
    By WATERWINGS in forum Technical Discussion
    Last Post: 06-02-2003, 11:38 AM
  4. Electric Fuel pump-vs- stock pump
    By B.Mac in forum Technical Discussion
    Last Post: 10-11-2001, 03:49 PM
