Results 1 to 3 of 3
03-04-2021, 04:42 PM #15000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 102
- 28
Electric pump, regulation and fuel/water filtration
Hey guys
It seems like every time I'm here I write a novel.
Sorry.
I've got an old 184 Champion. It has/had a 150hp OMC on it. The fuel pump failed and I couldn't get the rebuild kit before a tourney, so I installed a 73gph 4-7psi Electric. (tied into the kill so it also shuts down when the tether is pulled... before anyone jumps on that)
That motor has worked ok for me, but I haven't been overly happy with the performance.
So I invested in a 175hp 2.5L Mercury. I'm going to go through and freshen it up before I install it.
I was reading the spec for the Merc is 4.5psi. The OMC was 7.
Ok, I can add a fuel pressure regulator. Reading about them, the Non return style are cheaper, but aren't as good as the return style
The OMC had virtually no fuel filtration, so I added cute little filter.
I was looking at a Spin on style shown in the link below.
On that housing it shows 2 inlets and 2 outlets.
If I get a fuel pressure regulator that has a return, can I return fuel to the other Inlet of that fuel filter housing?
Thanks
https://www.cabelas.com/shop/en/bass...E&gclsrc=aw.ds
03-04-2021, 05:08 PM #2
Non-return regulators work fine on carburated engines. There's no fuel pressure in the float bowls.
DieselDood liked this post
03-05-2021, 04:53 PM #35000 RPM
- Feb 2020
- MinneSnowda
- 344
- 27
- 102
- 28
Electric water pump on v-drive
By bad_behavior in forum Jet Boats, V-Drives and Stern DrivesReplies: 3Last Post: 06-04-2008, 09:28 PM -
Installing Electric fuel pump on Looper, do I need to remove the VRO Pump?
By imq707s in forum Technical DiscussionReplies: 6Last Post: 05-12-2005, 02:21 PM -
electric fuel pump, through factory pump, or by pass?
By WATERWINGS in forum Technical DiscussionReplies: 6Last Post: 06-02-2003, 11:38 AM -
Electric Fuel pump-vs- stock pump
By B.Mac in forum Technical DiscussionReplies: 29Last Post: 10-11-2001, 03:49 PM
